scavage pump dying?
Old May 6, 2013 | 10:35 PM
Blackbird's Avatar
Default scavage pump dying?
getting some oil out of the turbo now to the point it lightly smokes all the time.
as well as i did get the sts oil buzzer once under light boost.
could worn turbo seals cause any of this or likely the pump is dying out and not pumping enough oil thru now?
I am pretty sure it's the pump but I would be bummed to spend $400 on a pump and still have the same smoking issue.
thoughts?
Old May 7, 2013 | 09:16 AM
Striker289's Avatar
On3 has a Brass gear scavaging pump. Mine only has a few hours on it but it seems to do the job well and its under 200 bucks.
