Pushing Water Maybe?
Old May 10, 2013 | 02:32 PM
mike13's Avatar
Default Pushing Water Maybe?
After I make a pass my water level drops about 1 quart, just low enough for the low water symbol to light on the dash. Doesn't seem to drop any lower when making further passes. The water is going into the overflow but doesn't siphon back. no other signs like water in the cylinders or around the heads.
Car doesn't run any hotter or show any signs of having issues. Using MLS gaskets on a iron block 390, 83mm turbo on 14lbs making 800-820rwhp.
Is this common or do I have a problem or overlooking something?
Thank You
Old May 10, 2013 | 03:13 PM
Forcefed86's Avatar
Thank You
Do you have any sort of catch can or evac system? Anytime I was pushing coolant I'd see it there first. Could just be your coolant system finding it's "happy place" .
Old May 10, 2013 | 03:56 PM
mike13's Avatar
yes catch can, nothing unusual. Hope it's the " happy place" for the coolant level.
Old May 10, 2013 | 07:55 PM
Forcefed86's Avatar
You'll probably be fine. Usually if you push coolant into the cyls you get a smoke show as well.
Old May 10, 2013 | 09:33 PM
Pocket's Avatar
^ And the O2 sensor for that bank flips out
Old May 12, 2013 | 01:01 AM
Ryans99ls1's Avatar
You are probably lifting the heads very slightly. Mine did it and did exactly what yours did. When the headgaskets got bad enough, it was pushing enough coolant into the overflow to blow the cap off at WOT. No smoke either. Swapped to ls9 gaskets/arp headstuds, problem gone.
Old May 12, 2013 | 02:59 PM
mike13's Avatar
[QUOTE=Ryans99ls1;17392634]You are probably lifting the heads very slightly. Mine did it and did exactly what yours did. When the headgaskets got bad enough, it was pushing enough coolant into the overflow to blow the cap off at WOT. No smoke either. Swapped to ls9 gaskets/arp headstuds, problem gone.[/QUOTE
Thanks, I have a set of LS9 headgaskets on the shelf. I'll pull it apart if it gets worse.
Old Jun 27, 2013 | 08:37 AM
Vetal's Avatar
I have similar problem. After few passes at 14-15psi coolant level in my radiator drops by 3-4 inches. And I don't see it coming back from overflow tank. In fact I don't see this ~quart anythere. What the hell is happening?? Where does the coolant go?
Old Jun 27, 2013 | 09:49 AM
Ryans99ls1's Avatar
Like i said above, you are probably lifting the heads ever so slightly and consuming the coolant. Its what happened to mine. It started just eating coolant and eventually it began pressurizing the coolant system and blowing the overflow cap off. It starts off as a very small headgasket breach and normally gets worse over time (i had stock 50k mile graphite gaskets, stock headbolts and stock heads).
The engine suffered no damage but driver side pistons were clean as whistle when i pulled the heads off lol
Old Jun 27, 2013 | 11:06 AM
Vetal's Avatar
OK but where does the coolant go? It can't be "consumed" in cylinders because pressure is blowing it away from cylinders. But where?
Old Jun 27, 2013 | 11:58 AM
Twin turbo c5's Avatar
Your probably good. I've had that happen.
Old Jun 27, 2013 | 12:36 PM
vwdave's Avatar
Just keep adding boost till you smell coolant, then back off.
Old Jun 27, 2013 | 01:57 PM
offaxis's Avatar
Out of the exhaust .
Old Jun 27, 2013 | 03:17 PM
I've been losing water for awhile on my 6.0 I turned it up to 20psi last weekend at the track and a finally blew the gaskets but my motor was bone stock with factory head gaskets and 182,000 miles.
Old Jun 27, 2013 | 03:19 PM
Ryans99ls1's Avatar
This.
Old Jun 27, 2013 | 03:21 PM
25thhawk's Avatar
Try a new radiator cap first. Mine would heat up, fill up the overflow and the cap was just loose enough that it wouldn't make a seal and suck it back into the radiator. I just bent the tabs on the cap so that it tightened up a little and that solved the problem.
Old Jun 27, 2013 | 09:15 PM
dmaxvaz's Avatar
Thank You
Is this a AES 390? Also what fuel are you running on 14psi boost?
Old Jun 27, 2013 | 09:25 PM
408GT's Avatar
This made me lol
Old Jun 27, 2013 | 09:29 PM
mike13's Avatar
yes, pump gas mixed with 114
Old Jun 27, 2013 | 09:51 PM
dmaxvaz's Avatar
What kind of timing are you running and what ratio of 93 and 114 octane are you mixing?
