Which precision 7675 is better value for money
Old May 11, 2013 | 02:57 AM
ls4_newbie's Avatar
Default Which precision 7675 is better value for money
Hi guys I'm looking at fitting a precision 7675 to my 5.3 engine. But is it worth spending the extra money on the CEA version which claims to be rated to 1200 instead of 1160 that the standard one is.
Cheers
Old May 11, 2013 | 06:21 AM
Nitroused383's Avatar
IMHO there is no point in the billet wheel on this turbo. The turbine wheel is the limiting factor in power on this unit not the compressor wheel. Might as well save a few bucks.
Old May 11, 2013 | 09:40 AM
02LS1ram's Avatar
Cheers
I said the same thing before I brought mine. Till I saw the great power guys were making with the norm journal bearing version. That alone told me to save that little bit of extra money and put it else where that is important.
Old May 11, 2013 | 10:42 AM
TurboJoe@Straightline's Avatar
I use a lot of these turbos, they are great any way, as said the turbine is the limiting factor with this turbo. The compressor not so much. Our chassis fab guy made 960 rwhp on a forged 6.0 and c16 . Also willamz car got upgraded to the pt from the tc and go look at his results
Old May 11, 2013 | 10:44 AM
droksformula's Avatar
Do some digging. There alot of comparisons from cast to cea. I would get the cea.
Old May 11, 2013 | 11:30 AM
ls4_newbie's Avatar
Ok cool guys thanks for the help as a comparison is there any other turbos that you could recommend that would be a better but In the same price range of the 7675
Old May 11, 2013 | 06:40 PM
It's hard to beat that unit for how physically small it is. There are other turbos that are a lot better value per hp but they are huge in comparison. The borg warner s475 and s480 are probably the best bang per buck if you have the room. I think they are in the $700-800 range.
Old May 12, 2013 | 01:09 AM
yelo04goat's Avatar
Got a similar turbo from turbonetics for sale it's bigger but it sure is pretty. 78 mm mid frame 1.14 ar t4 and 75mm turbine. Never mounted or used
Old May 12, 2013 | 02:20 AM
ls4_newbie's Avatar
well I was originally going to fit a ebay special gt45 but ive now decided against it. I think id have room for the borg warner, if not ill make it fit. Has anybody compared the 7675 and the S480. which would be the better turbo. Im aiming for over 700whp (750-800whp if im being optermistic) if that helps.
Old May 12, 2013 | 03:27 AM
yelo04goat's Avatar
the s480s have been making some great power.. 1000+ and the new billet wheel i think has made over 1200.. i think i have seen a few cars make as much as 900s on the 7675. but icould be wrong there. what is the price on that thing. PM me if you want to talk about the tnetics mid frame. its close to the size of s400 but not quite and its got ceramic ball bearings
if you got the room and what to save some $$ s400 is the way to go for sure. you can get a pricey unit with those too if you want to thought ~1600 with new billet wheel and all
Old May 12, 2013 | 05:05 AM
buick_lsx's Avatar
Standard s475 can get you there too if on a budget, my 6.0 makes 750 on ~16 psi and made 915 on ~18 and a 50 shot
Old May 12, 2013 | 08:28 AM
ls4_newbie's Avatar
My budget is upto $1500 if that helps
Old May 12, 2013 | 10:04 AM
jridenour31's Avatar
S480 with the 96mm turbine will make way more power than a 7675.
Old May 12, 2013 | 04:26 PM
My friend made 832rwhp with his billet 7675 on only 19psi pump gas on his 3valve mustang. I realy dont see a cast s480 outpowering it by much if any. Plus just by smaller size alone the pt will spool nicer.
