russ K idle config works!
UNDER PRESSURE MOD
Nice sized cam. I have a 227/235 on a 113lsa with .614/.621 lift, so there's no reason why I shouldn't be able to get my idle down to the mid 700s as well. It's idling fine right now at 800, but I'll try dropping it a little this weekend.
Last edited by The Alchemist; 05-15-2013 at 02:18 PM. Reason: Corrected my lift specs for my cam.
Alchemist,
Your cam actually only has 2 degrees less overlap@.050" than this camshaft. Now, since your cam uses LSL lobes it has much less seat to seat overlap(AKA .006" or @TDC) than this camshaft as Denmah's cam uses a much milder slower lobe.
You should have no problem idling it down some.
UNDER PRESSURE MOD
Actually, I think it uses LSR lobes, I think, gotta check again, but I do beleive this is the cam I'm running, but I'm not at home, so I don't have my cam card in front of me.
http://www.compcams.com/Company/CC/c...csid=1402&sb=0
EDIT: just did some reading and realize that the LSR cams use LSL lobes. My bad.
