LS9 head gaskets..... why....
Old Mar 8, 2018 | 10:36 PM
  #41
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
More layers has nothing to do with compression. Overall thickness is the same.
But any of the GM MLS gaskets work superbly, I'd always prefer to use the correct bore'd gasket for my engine unless there was no alternative.
I'm sure you just misspoke, but to clarify, overall thickness is NOT the same. The added layers do add thickness and can lower compression. Also, having a gasket of a larger diameter than your bore size lowers compression. I do agree that even the simplest of these gaskets do an amazing job, but there is a difference. We just shipped almost 20,000 middle layers for 5.3 gaskets today, so I have some knowledge of what I am talking about.
Old Mar 9, 2018 | 04:27 AM
  #42
stevieturbo's Avatar
Well stock LS1 5 layer and LS9 7 layer are the same overall thickness.
Number of layers does not dictate how thick the overall gasket is, because the individual layers themselves can and are all different thicknesses.
So you could easily have a 3 layer and 7 layer the same overall thickness and some brands can be bought that way.
Old Mar 9, 2018 | 09:06 AM
  #43
tblentrprz's Avatar
Is a larger bore diameter fire ring more stable being closer to head bolt clamping force (especially on factory head deck thickness)?
Old Mar 9, 2018 | 09:14 AM
  #44
Forcefed86's Avatar
Could be. I’ve found on alum small bore blocks the LS9 HG fire ring sits outside the cylinder sleeve. Which I’d assume is less than ideal. That said I’ve had issues with Felpros small bore MLS gaskets not sealing as well as an LS9. (3 separate instances) No direct experience with the OEM small bore or LS1 MLS gaskets though.
Old Mar 9, 2018 | 02:42 PM
  #45
Project GatTagO's Avatar
So is anyone making a better gasket for the 5.3L bore?
Andrew
Old Mar 9, 2018 | 05:39 PM
  #46
Game ova's Avatar
The resurrection continues.....
Old Mar 9, 2018 | 06:27 PM
  #47
truckdoug's Avatar
Talk to me about rod bolts bro, I'm shooting for 500 wheel 😂
Old Mar 9, 2018 | 06:30 PM
  #48
Game ova's Avatar
No doubt. I'm just hoping I can will myself to pull my fuel pump tomorrow, cars been down for weeks now 😳
Old May 11, 2025 | 07:48 PM
  #49
boostedfoxbody90's Avatar
Originally Posted by Scoggin Dickey
He's also got a 6.0, not a 5.3 so it's more suited to his setup to use them. Besides that, I've never said the other stock gaskets were as good as LS9 for holding boost. I said that on a smaller bore they hold a good amount without issues and that after level you really need to spring for the properly sized Cometic.
I've plainly explained the gap it leaves between the head and deck of the block and this IS NOT RIGHT. I don't care how many people have done it without known issues, that doesn't make it acceptable to keep recommending it to people who want to do things right. You're cramming air/fuel mixture into that gap under boost and either leaving unburnt air/fuel mixture in the gap after combustion, or you have combustion happening between the head and deck. Either way it shouldn't be considered acceptable. Ideally you want to burn all of your air/fuel mixture and you want to do so in the combustion chamber.
I've said all I can say to try to inform the masses on this subject and giving information is really my only goal here, not to get into an argument. You can take it or leave it, it's just an opinion. I would never put an engine together intended for 20+psi and not put the right head gasket on it for the application and I recommend that you guys consider the same.
Consider your goals, consider the information given, and run whatever you choose with confidence
I know this is a super dated thread and I apologize for bringing it back up, but when you say cometic are you referring to a mls or composite gasket?
Old May 11, 2025 | 07:50 PM
  #50
I would assume MLS.
Andrew
