Meth/E users, how much time?
That's the thing though, with water you can get the cooling and anti-detonation without having to dump shitloads in.
Like with any fuel, it's all about using appropriate amounts for the application. If you use the wrong amount it isnt the fuel's fault. It's the tuner/operator.
But with methanol, it really wont matter how much you inject, you shouldnt experience a negative side, but then at what point should you just run methanol as a fuel in the first place ?
Im going to have meth added and tuned on my formula , made 416 before on a 4-6 lbs setup with tons of belt slip to now a setup that should have 8-9 along with meth .
i also dont believe that spraying directly on the iat sensor only shows the temperature of the liquid. ive proved that wrong.
my last turbo setup, with water injection, the water nozzles were less than 2" from the iat, and one nozzle was directly opposite, which means it was spraying the iat sensor.
i was spraying ice water, with ice cubes in it, lol. you would think that spraying onto the iat sensor, it would read close to 32 degrees(or whatever the temp of ice is) but i was seeing 124 degrees(without water injection its close to 300 degrees at 15psi), which tells me that vaporisation is damn near instantaneous and that ice water injection works amazingly to cool the charge.
As several of you have hit on pressure is an extremely important factor as well. Lowering the pressure on the shell side in one of our exchangers 5psi can drastically swing the efficiency of the exchange. 5psi in the manifold vs 30 is going to make a very big difference. The heat in the chamber should still be enough to flash it just as it passes the intake valve though. That's a hard piece of data to extract unfortunately.
I agree you aren't measuring liquid, but that doesn't necessarily prove the vaporization is instantaneous in that situation.
Aaaaahhhh
Ok
On dyno results years ago, over 100deg c can be pulled out of iat
With in 6 inches of runner
Next picture is not mine, but I'm sure the owner is fine me using it...
Pyro gauges used on dyno and logged
Btw
Something not said here
Compression creats heat too
Put your hand on shop air compression discharge...
Major point also
It's the size of fuel droplets that allows the vaporisation as well
Cheers
I've found different
More fuel, get a/f down around 3.4-3.5 ( depending on your static comp
)Then add timing, read base ring and earth strap on plug
Which lets face it...will get skewed readings because of the liquid fuel too.
Even charge temp measured close to a meth nozzle. How much is actually an accurate reflection of charge temp, and how much is simply some cold methanol hitting the sensor ?
Measured there, top of runner, turbo discharge...
And ...have a think about relationships of pressure , temp , and what happened to both ....
Back in the 90's , down nozzles were banned from some blown alcohol classes, cause it put fuel right on the intake valve....
That makes you think more, that maybe it was advantage..
Sprint cars have down nozzles , na fuel system....
If fuel is still a liquid , once compression has occurred, unless you have a pro mag 44 etc or msd8 /10... The fuel cycles thru the motor and your bscf numbers get thrown off...
Spark plug is true temp reading tool...
