Initial startup running too rich.... any ideas?
Old May 20, 2013 | 07:36 PM
MIGHTYMOUSE's Avatar
wait hold on, you did an ls turbo build and ended up rich? i must be doing it backwards...
Old May 21, 2013 | 07:03 AM
redtan's Avatar
He said it has a base tune in it already so I would think it would be good enough to idle and run.
True that he already has a tune, but that doesn't mean that it's necessarily a good enough one to keep running (especially if the injector data is wrong).
I still think that it's tune related, especially if it's an SD tune that takes more finesse before it can run smoothly.
Old May 22, 2013 | 12:40 AM
Johnv's Avatar
Could be injector data,
or not scaled for a 2 or 3 bar Map sensor,
air intake temp sensor not connected
VE table too far off for your engine combo.
Old May 22, 2013 | 03:14 PM
JetMech99's Avatar
Sooo because of the rich tune the plugs are fowled and there's GAS IN MY OIL. How the hell can a start up tune be THIS FAR OFF??? So the guy sends me another start up tune.... car still won't run..... should I find another tuner?
Old May 22, 2013 | 04:33 PM
jrpimp00's Avatar
Just trailor the car to him, hes just guessing with the startup tune. He needs data from the car
Old May 22, 2013 | 05:30 PM
05_quick4door's Avatar
Do you have the correct map sensor installed for the 2-3 bar os?
Old May 22, 2013 | 06:23 PM
JetMech99's Avatar
Yes, it's a 2 bar from an '05 Cobalt SS.
Old May 22, 2013 | 06:46 PM
rotary1307cc's Avatar
Perty easy to just drop fuel pressure enough so you can get it to him.
Old May 22, 2013 | 07:06 PM
JetMech99's Avatar
I have a stock FPR, so it's not adjustable for me. Are their other ways of doing it?
Old May 22, 2013 | 07:49 PM
itsslow98's Avatar
Take the car to him, your asking an awful lot from him for a base tune with such a specific setup.
Old May 22, 2013 | 08:01 PM
maxgee's Avatar
You have hptuners? If so, I assume you are uploading the tune he sent you?
Old May 22, 2013 | 08:05 PM
  #32
1969x11's Avatar
Get you a good wideband installed too,could save you a motor.
Old May 25, 2013 | 09:09 PM
  #33
JetMech99's Avatar
After getting it to him and on the dyno, he's thinking the ECM may be bad. What would cause a ECM to go bad? It worked just fine last fall when I stored the car.
There were some weird reading while on the dyno. The MAP sensor was reading boost even with the car not running, the TPS shot to 13% at one point, and he was saying when he would write something to the ECM it would revert back to the previous settings after he keyed it off and on again. Confused....
Old May 25, 2013 | 09:30 PM
  #34
maxgee's Avatar
Yes that's is weird. Call Hawks third gen to see if they have an ECM for you.
