Initial startup running too rich.... any ideas?
Old May 19, 2013 | 01:48 PM
JetMech99's Avatar
Default Initial startup running too rich.... any ideas?
Hey guys, just went to start my Huron Speed kit with a TC-76 for the first time and she is running PIG RICH! So much the car wont stay running. Just fills the garage with smoke and dies out. Any ideas? Anything to look for? I had my tuner do a startup tune on my PCM, running SD.
More details are 80 lb deka injectors and a walbro 255 with the hotwire kit.
Turbo noob needs help!!! Thanks in advance!
Old May 19, 2013 | 02:29 PM
Cam72aro's Avatar
Too much fuel in the ol table. Injector table not correct. Could be many things.
Old May 19, 2013 | 03:12 PM
JetMech99's Avatar
So basically bad tune? I was just wondering if there's anything mechanical i could check out. Thanks for the response!
Old May 19, 2013 | 03:19 PM
Blackpanther99's Avatar
Check with your tuner, thats what I would do to beguin with. How rich is the car running? Seems real bad.
Old May 19, 2013 | 03:21 PM
Superman09's Avatar
LS1Tech Sponsor
Who is tuning the car? I think I may know and can let him know to get you set-up or corrected ASAP!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
JetMech99's Avatar
Yea i'll shoot him a call first thing in the morning. It's running wicked rich.... never seen anything like it lol!
Old May 19, 2013 | 03:24 PM
JetMech99's Avatar
You have a PM Jon
Old May 19, 2013 | 03:26 PM
Superman09's Avatar
LS1Tech Sponsor
Originally Posted by JetMech99
You have a PM Jon
__________________
Old May 19, 2013 | 05:55 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Blowing smoke isn't a good thing. I'm not a turbo expert, but that sounds like your burning oil. Even running rich at idle, you shouldn't be seeing smoke, at least I never have.
Old May 19, 2013 | 06:02 PM
JetMech99's Avatar
It smells like gas, even burns the eyes. I don't have any oil in the piping... would I see any there is the turbo was dumping oil?
Old May 19, 2013 | 08:57 PM
wild1100's Avatar
What are you using to tune
Old May 20, 2013 | 05:09 AM
Camaro9969's Avatar
It's all in the tune get the injectors scaled down and it will lean itself out have that checked and then post in the tuning section
Old May 20, 2013 | 05:15 AM
itsslow98's Avatar
Make sure your Coolant temp sensor is plugged in and working. That will dump fuel on startup.
Old May 20, 2013 | 06:02 AM
JetMech99's Avatar
I checked the coolant sensor and it's hooked up, if it's working or not I don't have a way to tell. I'll most likely be running the pcm up to the tuner this week for a reflash.... Ugh.
Old May 20, 2013 | 07:06 AM
Camaro9969's Avatar
You can't bring the car to him?
Old May 20, 2013 | 09:00 AM
JetMech99's Avatar
No, it's running way too rough to drive it an hour. I have the actual dyno tune scheduled for this Friday, just need it to start first to be able to get it there lol. Thanks for all the ideas guys!
Old May 20, 2013 | 11:44 AM
Camaro9969's Avatar
Get AAA 100 mile free tow.
Old May 20, 2013 | 12:37 PM
JetMech99's Avatar
lol... now THAT'S not a bad idea!
Old May 20, 2013 | 12:46 PM
redtan's Avatar
Pure and simple it's a bad tune.
With the significantly bigger injectors you need to scale those correctly in order for it to run properly.
If you have 80lb injectors spraying the same pulse as a stock 28lb injector you're going to have problems. The computer doesn't know what injectors you have on there, so if the tune is close to stock it knows to keep the injector open for a certain amount of time. If those injectors are much bigger, that same pulse is going to deliver alot more fuel.
A proper tune with the correct injector data will keep the car running just fine to putt around to a tuner.
Old May 20, 2013 | 05:57 PM
itsslow98's Avatar
He said it has a base tune in it already so I would think it would be good enough to idle and run. I would tow the whole car to the tuner so he can troubleshoot it if its not the tune. With AAA if you just sign up I believe you cant tow anything for the first week or two.
