will s480 be too much for 383 5.3?
Old May 22, 2013 | 09:09 AM
nastylx's Avatar
Default will s480 be too much for 383 5.3?
Planning to start my build soon and am looking to go forged stroker, im plannin to do a 383 kit, aftermarket heads, custom spec'd cam, edelbrock proflo and other mods and was wondering if my original plan to do single front mount s480 will work? advice?
Old May 22, 2013 | 09:23 AM
Fahrenschnell's Avatar
Yep....383 should light it off nice.....get the T6 version with 1.32AR....Will make great power.
Old May 22, 2013 | 10:22 AM
hellbents10's Avatar
LS1Tech Sponsor
S480 on a 383 is a great choice with the 1.32 T6 housing.
Old May 22, 2013 | 10:30 AM
BanditDave's Avatar
Cam it properly and it will be a beast....give Martin a call at Tick or PM him on here. He just spec'd me a cam for a relatively similar combo. He knows his stuff! Really excited to see what it does!
Old May 22, 2013 | 11:44 AM
nastylx's Avatar
Thats who i had in mind, lookin to make 7-800whp on race tune an then turn it down an drive it around whenever i please. how unrealistic is it to aim for 20mpg on low boost drive tune?
Old May 22, 2013 | 11:45 AM
nastylx's Avatar
Also wondering what aftermarket heads would run best with this setup, i lack lsx knowledge as this will be my first lsx motor
Old May 22, 2013 | 11:56 AM
jridenour31's Avatar
Why use aftermarket heads if you're only shooting for 800hp?
Old May 22, 2013 | 11:58 AM
nastylx's Avatar
Will eventually bump it up, really not sure what the stroked 5.3 with s480 is capable of
Old May 23, 2013 | 08:07 AM
turbocamaro125's Avatar
built a ls1 383 with 317 heads and pro flo intake 232/240 595/608 114 cam s480 1.32 and it was a beast. 6sp car too. 4th gear 1800rpms was 1psi and like 2600rpms was 15psi it spooled so fast.
Old May 23, 2013 | 09:47 AM
Sales@Tick's Avatar
That turbo is perfect for a 383. I'd be more than happy to do a cam for your set-up.
Old May 23, 2013 | 11:03 AM
nastylx's Avatar
Cant wait, i'll hit you up when the time comes. i'm on the fence as far as heads go and would like to get an estimate as to what kinda power im looking at with a 5.3 stroked to 383 an the s480 at about 15-20psi, through a th400 with 3500 stall and 8.8 with possibly a 3.08 gear
Old May 23, 2013 | 11:56 AM
Blackpanther99's Avatar
That thing will be a beast on a T6. Goodluck man. Martin will take care of the cam for you
Old May 23, 2013 | 12:05 PM
nastylx's Avatar
Main reason im doin forged and everything is a buddy and i are having a friendly rivalry, he's doin a junkyard 5.3 budget build on his 71 camaro an always has somethin to say an thinks im retarded for doing forged, my arguement is why build it to break an have to rebuild all the time when you can build somethin strong that will last, yes his way is cheaper "right now" but in 5 yrs he's gonna be through a few motors an have to rebuild all the time which could be time spent at the track and on the street. i think my 383 fox coupe with s480 will put an end to the disagreement
Old May 23, 2013 | 03:48 PM
Sales@Tick's Avatar
You're going to make a lot of power that is for sure! What heads have you been contemplating?
Old May 23, 2013 | 04:07 PM
nastylx's Avatar
Estimate on "alot"? And i still have some research to do, just want to do whats best for the setup, port an polish, valve job, dual springs, rr's, valves, pushrods, valve girdles, and what exactly is the "trunion" upgrade?
Old May 23, 2013 | 04:11 PM
Taubr Unit's Avatar
A 383 isn't a 5.3 lol....
Someone had to say it and busy your *****, lol
nastylx's Avatar
An Martin i sent you a pm
Old May 23, 2013 | 04:12 PM
nastylx's Avatar
It is if you put the stroker kit in it....
Old May 23, 2013 | 04:15 PM
nastylx's Avatar
What whp did you make?
Old May 23, 2013 | 04:52 PM
Never had it on a dyno about I'd say 750whp
