Hitting the track here soon.
Old Jun 3, 2013 | 10:15 PM
bad6as's Avatar
Didnt make any good passes, afr super rich, wastegate not doing what i ask, then i hurt the trans. Went 113mph to the 1/8th on one pass, but its really not any thing to be happy about.
i cant seam to figure out how to long my wideband. Any one be able to help me on that?
Old Jun 4, 2013 | 09:18 AM
rotary1307cc's Avatar
What ems and WB?
Old Jun 4, 2013 | 04:46 PM
bad6as's Avatar
fbody pcm and hp tuners and a aem ugeo
Old Jun 4, 2013 | 10:26 PM
dudeman's Avatar
damn. what happend to the trans?
Old Jun 4, 2013 | 10:44 PM
bad6as's Avatar
not sure, i put it in 1st or 2nd and its in 3rd. dosent shift. all ways in 3rd. but i still have neutral and reverse. i pulled it yesterday and droped it off to the trans guy today, hope to know tomorrow
Old Jun 4, 2013 | 11:01 PM
Pewter53's Avatar
one of the nicest ls fox bodys i have ever seen.
Old Jun 5, 2013 | 08:37 AM
The aem has a white wire. That is the linear 5v output
I am just assuming you have a pro hpt interface if not say so
Hook the white wire into aux1 on the interface(pin 1) as well as a ground (pin 5)
Under table view scanner with no log open insert on aux1. Pick out the aem
Also insert it in the table view up above the input section
Once it is in the table view you can use it in the chart view
Old Jun 5, 2013 | 08:48 AM
bad6as's Avatar
i made this in the table sensor as none
PID.2810]/.5+10
but i didnt make one for egr postision in v so i did that but havent gotten to try it yet
i have pro but i all ready have the wideband wire hooked to the egr wire. and i dont want extra wires laying around.
Old Jun 5, 2013 | 09:33 AM
Is the correct number showing up in the table view for you?
Old Jun 5, 2013 | 09:39 AM
bad6as's Avatar
havent gotten that far, it kept saying unsupported peramiter when i started to log. then i turned on the egr in the tune. same result. i just made the erg voltage in the table but i havent got to try it yet
Old Jun 5, 2013 | 09:58 AM
Yeah I don't have my laptop to see the pid and sensor list .
Let us know if it works
Old Jun 5, 2013 | 12:06 PM
  #32
dudeman's Avatar
PID.2810]/.5+10
that's the same pid I used except the 10 is a 9.7 on mine. you will need to adjust that number if the scanner doesn't show the same a the wideband itself.
Old Jun 5, 2013 | 12:35 PM
  #33
I had to write my own aswell and it is also at 9.7 lol
Always was a couple tenths off on the scanner compared to the gauge when using the default aem
Old Jun 5, 2013 | 08:36 PM
  #34
bad6as's Avatar
thanks for all the kind words on the build guys. : )
Well i got arf to work thanks to all.
had to change pid to 2811 and also do the egr postion in v
Ill have to wait for my trans to get back so i can start it and the voltage .
now i have a 3 bar map sensor and i have it converted to read psi. Is there a way to get it to read only boost? the function i have for it now is pid.2334-101/101/14.7. at vaccume it reads negtive psi. Ide like to show 0
Old Jun 5, 2013 | 09:13 PM
  #35
dschmittie1's Avatar
But it is correct to see negative psi at idle(as it is seeing vacuum). It should read 0 at Key on engine off
Old Jun 6, 2013 | 05:18 AM
  #36
bad6as's Avatar
Yeah i understand that, i was just wondering if it was possible for it to only display positive values on the.charts
Old Jun 6, 2013 | 06:05 AM
  #37
pid.2334/101/14.7. I think that would only display positive numbers. But remember then it will show 28 psi when you are really only seeing 14
Old Jun 7, 2013 | 10:49 PM
  #38
bad6as's Avatar
Well the 3rd gear clutches were toast. Said it took a good bit of effort to get them out. He said something about the centrifugal force was causing third to drag. I think he said it was the thing the sprag is in? I dont know much about the inner workings of a trans. But he said going to some aluminum drum from coan will solve the problem. Some type of spring i it is stronger too. Ill have hime make me a list of what he puts in it this time. The drum is about 700 itself plus some new clutches and a sprag and some new bushings. Yay another $1400 : (
Old Jun 8, 2013 | 01:16 AM
  #39
LilJohn's Avatar
Make him get a second opinion on that drum. Ive never seen an aluminum drum in a turbo car trans.... ever.
Old Jun 8, 2013 | 01:29 PM
  #40
bad6as's Avatar
maybe im mistaken on what he told me. but i know he wants to do something thats aluminum. what causes 3rd gear clutches to burn up
