Changing Exhaust AR on Incon?
Old Apr 26, 2004 | 01:04 PM
Phate's Avatar
Default Changing Exhaust AR on Incon?
Guys,
Looks like I am going to go ahead and run the gtbb37s that I just had rebuilt. I was talking to the guys at Innovative Turbo and we decided that unless I was going to go with a completely custom system I was better off just using what I had. We did discuss a few options though.
I currently have the .64 AR exhaust housings that came with the kit. I am thinking about going to a .86 exhaust housing to help the turbos flow a bit more up top. Do you guys think that it is worth the effort to make this move? Think I will gain anything?
These are going to be on my 408 8.5:1 motor.
Thanks,
Old Apr 26, 2004 | 07:06 PM
cablebandit's Avatar
Hopefully Harlan will jump in here. He maxed his and should have enuff data to know what maxed first. he didn't have the 37s tho.
Old Apr 26, 2004 | 07:24 PM
red ws6 99's Avatar
Based on my research it is the exhaust side that limits the flow on the Incon setup. I had mention this to harlan before he really started trying to max out the turbos. I never did crunch the numbers all the way through.
Gary
Old Apr 26, 2004 | 10:05 PM
Phate's Avatar
Matt, care to chime in? How do you guys think that this change will effects spool?
Thanks,
Old Apr 26, 2004 | 10:50 PM
2FAST4U's Avatar
What type of maf/pcm are you using? As the Incon turbos are already good for more that the stock MAF can handle!
I just got my Incon turbos built and would pay more in a heart beat if I could use the power made! I would buy the bigger AR a just wait to install when I go to a DFI system!
http://community.webshots.com/photo/...36873534jIGrdM
Old Apr 26, 2004 | 11:14 PM
Phate's Avatar
Computer will be Gen7 after I see how far I can go on the stock PCM. I am pretty confident that I will be able to get the car to the 800rwhp mark before I need to go to an aftermarket management system though.
Old Apr 26, 2004 | 11:49 PM
2FAST4U's Avatar
With alky or water or what?
Old Apr 27, 2004 | 11:21 AM
Phate's Avatar
Probably propane initially (since I already have that kit on the car). Eventually I will probably go to a progressive alky system spraying methanol.
Old Apr 27, 2004 | 11:33 AM
2FAST4U's Avatar
IC IC but back to the AR. talk Harlan anybody can do the math? When I ordered my CHRAs and compressor housings Choper at Limited Enginering said I could go up one size in chras but the turbin and compressor would need to be milled out a little. And the gain would only be say a max of 50hp total as the turbo is still only so big and and can only flow so much!
Old Apr 30, 2004 | 09:25 AM
TurboSS's Avatar
Scott,
About 40 hp gain going to a .86 housing and a change of about 400 rpm on spool up.
Old Apr 30, 2004 | 09:40 AM
smokinHawk's Avatar
id imagine since your using a 408 cubed motor that the larger Ar exhaust would be better for it, with that many cubes i dont think spool will be an issue.
Old Apr 30, 2004 | 11:24 AM
Phate's Avatar
Thanks for the responses guys, I appreciate it.
Scott
