Methanol Injection Brands...
Old May 31, 2013 | 02:28 AM
tylert14's Avatar
Default Methanol Injection Brands...
So I'm looking for a good company to talk to about a straight methanol injection setup. Any sponsors here? Anyone care to give some recommendations?
Money is not concern here, I am looking for the best components possible, and a company with the knowledge to steer me in the right direction with some questions.
Thanks fellas.
Old May 31, 2013 | 05:46 AM
Blackpanther99's Avatar
For straight methanol I have read that Alky-Control and Alcohol Injection Systems are top notch. That goes for Aquamist also. I have read of people having issues with their Snow's Water-Meth kit when it comes to running 100% Methanol due to the pump.
Old May 31, 2013 | 06:10 AM
*WS6*'s Avatar
Ive been running the alky-control system for 4 to 5 years now. The boost sensitive progressive controller works well and the system was relatively easy to install.
Julio has always been there for help and for good measure he rebuilds my pump every other year or so for under $100.
He can design a kit "one off" for you or you can take one off the rack if a methanol resevoir isn't an issue.
He also makes an add on pressure sensor that I was able to configure to have my data logger see and log. It's very helpful to see when the system tips in and the rate of climb vs. boost.
His kits can be made in single,twin and triple nozzle with nozzle sizes ranging from M5,10,15.
Old May 31, 2013 | 07:10 AM
MonmouthCtyLS7's Avatar
Alky Control is good from what I've heard...running Aquamist here.
Old May 31, 2013 | 07:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
We've always use Alky control. Top notch kits that last. Still have a lot of his kits 8-10 years old out there running daily. Our shop car runs his kit and has gone 8.4's on 93 octain so far.
Old May 31, 2013 | 08:57 AM
35thsscamaro02's Avatar
I have AIS. But just go with alky control much beter customer service.
Old May 31, 2013 | 09:25 AM
71 chevy's Avatar
a little bit of knowledge goes a long way. and even though money is "not a concern", if you get knowlegde you will find that most of the water injection kits are about 80% homogenous, and that you can build your own, with the same components for about $150.
Old May 31, 2013 | 08:05 PM
See those alot in the Diesel forums.
Old May 31, 2013 | 10:15 PM
Detoxx03's Avatar
Alky Control is where it's at
Old May 31, 2013 | 11:20 PM
I8UR4RD's Avatar
I run alky as well. If i were going with one of the cheaper brands I would lean towards Devils own.
Why alky? as mentioned customer service. the quality of the hardware and pump and the great track record.
Old Jun 1, 2013 | 07:06 AM
sixt5's Avatar
I ended up piecing mine together used on eBay. Alky I junction pump and tank combo and Devils own controller.
