Spark plug wires for 1000hp 408 lq4 turbo motor.
Old 06-06-2013, 02:50 PM
zapp109's Avatar
Default Spark plug wires for 1000hp 408 lq4 turbo motor.
Curious what plug wires you guys are running? I want to do this once, so we have Stock, MSD and ????
Old 06-06-2013, 03:13 PM
LS1Tech Sponsor
Slowhawk's Avatar
I run stock GM
Old 06-06-2013, 07:13 PM
SPRAYED 01's Avatar
Stock, you will gain nothing going aftermarket.
Old 06-06-2013, 09:36 PM
bad6as's Avatar
I got some ls2 pull offs from ebay 3 years ago, still going strong.
Old 06-06-2013, 09:47 PM
LS1NOVA's Avatar
I run stock LS2 also. If you want the best, Firecore50.
Old 06-07-2013, 02:49 AM
jridenour31's Avatar
I've only used stockers, haven't had any reason to switch.
Old 06-07-2013, 06:38 AM
skinnies's Avatar
I love my stock wires, just ones off jy motors. The firecore50 ones look badass though, when I do relocated coils I'll finally buy a set of those!
Old 06-07-2013, 09:45 AM
OldGold's Avatar
A/C Delco.
Old 06-07-2013, 04:12 PM
zapp109's Avatar
good to know thanks for the replies looks like ill pick up some stock wires
Old 06-08-2013, 10:51 PM
driven87's Avatar
I have firecore 5.0 wires on mine
Old 06-08-2013, 11:20 PM
allout06's Avatar
stock truck wires here
Old 06-08-2013, 11:29 PM
MillsMotorvation's Avatar
stock
Old 06-09-2013, 12:39 AM
FasTimeSS's Avatar
My stock wires have held up great I can't complain even with the factory heat shield boots.
Old 06-09-2013, 08:43 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Firecore for me as well. If nothing else, they look good and I like the way the click on / off the plugs.
Old 06-09-2013, 09:41 AM
Camaro9969's Avatar
Stock are fine but If you want a quility product the firecore 50 are the way to go. There's tests on yb showing some gains. If your going to be buying new might as well spend the extra $$
Old 06-09-2013, 11:14 AM
z28boysteve's Avatar
Omnispark from O'Reilly auto parts
Old 06-09-2013, 01:08 PM
Blackpanther99's Avatar
My tuner used stock wires on his 408ci on boost for a long time with no issues.
Quick Reply: Spark plug wires for 1000hp 408 lq4 turbo motor.
