plug and play Micro2 for LS engines going up for sale tomorrow
Old 06-19-2013, 01:42 PM
Moderator
denmah's Avatar
Default plug and play Micro2 for LS engines going up for sale tomorrow
sneak peek since i do the testing for mike @ efi source, this will be going on sale tomorrow for $795 tomorrow complete, wiring harness, ecu, everything you see in the picture, fused, relays you name it, this is pretty ****** awesome hahah.
Old 06-19-2013, 01:48 PM
Rogue Status's Avatar
Looks awesome!
Old 06-19-2013, 02:31 PM
atomic 6's Avatar
This should make it as easy as it gets.
Old 06-19-2013, 02:34 PM
badhombre's Avatar
looks like a nice setup. very clean and organized
Old 06-19-2013, 02:41 PM
Beanslsxnova's Avatar
Is this something you would recommend for someone who's trying to learn how to tune? I'm tired of paying for tunes. I was looking at the holley set up, but that bitch is pricey!
Old 06-19-2013, 03:16 PM
looter's Avatar
how does this compare featurewise to the gold box?
is it a few hundred more well spent?
Old 06-19-2013, 03:21 PM
Moderator
denmah's Avatar
absolutely easy to plug in and although there are lots of tables for advanced features its easy to get your feet wet with the fuel and spark only tables to get your car running and if you change something to retune easily
Old 06-19-2013, 03:22 PM
Moderator
denmah's Avatar
the gold box has an incredible feature set, but if you are building a budget car and you dont want to touch wiring at all, this is the best plug and play for your money, and i think also the cheapest that you can hook right up and tune in real time
Old 06-19-2013, 03:26 PM
Moderator
denmah's Avatar
could you imagine this happening we were testing to see if the micro2 would work over the phone hahah, pretty awesome
Old 06-19-2013, 05:32 PM
jleews6's Avatar
So basicaly ,if you had a motor sitting in a car everything you need to make it run is in this kit? You dont use any of the factory harness or computer? I would just plug this into my laptop?
These questions may sound dumb to you but I am completely lost on EFI and computers.
Old 06-19-2013, 07:12 PM
Moderator
denmah's Avatar
valid questions, not a problem
yes you can plug this into a motor on an engine stand and fire it so long as you have fuel going through the stock intake.
it comes with EV1 connectors, he sells plugin adaptors that swap it to ev6 for an additional 30 dollars i believe.
or you can cut them off and put on whatever injector piggy you want
but yes.
it has the new style map sensor plug for the stock 1bar map, you could pplug and play a 2.5 bar zr1 style map or buy an older style 3 bar map and pigtail from him or anyone else and throw that on too and then read up to 30lbs of boost
then yes the tuning software for a laptop or computer is free from Tunerstudio for Megasquirt based ECU's wich this is
Old 06-19-2013, 09:11 PM
james97cobra's Avatar
Does this read both high and low imp. injectors? Sorry if I missed that part. Thanks.
Old 06-19-2013, 11:07 PM
Moderator
denmah's Avatar
it can do high and low yes, but using highs is easier, some low's might need fine tuning wich can be a pain in the ***
Old 06-19-2013, 11:41 PM
merim123's Avatar
what are you guys doing for gauges that go this route?
Old 06-20-2013, 08:45 AM
LS1Tech Sponsor
Huron Speed's Avatar
this is awesome! i dont think you could make an ls swap into anything much easier than with this. very cool product.
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
Old 06-20-2013, 08:52 AM
Compressor Surge's Avatar
www.autometer.com
Old 06-20-2013, 08:55 AM
http://www.tunerstudio.com/
Old 06-20-2013, 09:01 AM
Professor_speed's Avatar
Great job and price point, at that price I don't even think I would bother with stock harness stuff for a swap.
Old 06-20-2013, 10:56 AM
merim123's Avatar
Originally Posted by Compressor Surge
you going to stick an android tablet in your dash? or drive around with a laptop for gauges. doesn't sound like a clean solution.
Old 06-20-2013, 11:22 AM
asb2106's Avatar
I'd like to think a tab could be done cleanly.
I have a swap job sitting in my driveway that would be perfect for this harness Ill be watching these
Quick Reply: plug and play Micro2 for LS engines going up for sale tomorrow
