Poor 60' times
Old Jun 28, 2013 | 10:52 AM
MillsMotorvation's Avatar
Need to change your gears for one.
Old Jun 28, 2013 | 12:34 PM
jridenour31's Avatar
Gears certainly aren't perfect but they're no different than if he was running 3.55's with a 26 inch tire.
Old Jun 28, 2013 | 03:21 PM
Vcious04's Avatar
It's all in your tune.
Just be carefull, running blind (no wideband log and a ton of timing) is pretty scarey.
Old Jun 28, 2013 | 03:25 PM
HRHohio's Avatar
2.73's on 26" tire... THAT's where it's at baby!
Old Jun 28, 2013 | 09:27 PM
Point is, the gears aren't causing 2.2 60' s.
Old Jun 28, 2013 | 09:35 PM
HRHohio's Avatar
No, I know. I was being serious though.... I'm going to be running 2.73 rear in my 72 Camaro with 26" DR's. Why? Because I already have them. lol.
The right cam and tune however will wake his car up.
Side note: Wicked69 and the Big Bang Theory Article from Hot Rod Mag are my inspiration.
Old Jun 28, 2013 | 10:03 PM
I haven't gone that tall just because I've never had 2.73's laying around lol. I have used 3.27's with a 28" tire, though, and it works really well. I'm not sure at what point gears become too tall in a turbo setup. I do know I've never found it with a 3-speed.
Old Jun 29, 2013 | 05:42 AM
99VetteFRC's Avatar
Big Bang Theory was one of my inspirations too. They sure don't tell you everything. And be carefull with the part numbers, some are not correct.
I had the 3.08s in the car but it makes the car hell to drive around hilly PA. I did get a T56, Spec twin disc clutch, trand rebuild kit, and clutch master cyl last night for $200. WOW! I need bellhousing, shifter, and a few odds and ends. Then we will see if I can get the turbos screemin'.
Old Jun 29, 2013 | 07:27 AM
Oh yeah, I definitely wouldn't go that tall with 30" tires.
Old Jun 29, 2013 | 03:48 PM
99VetteFRC's Avatar
Well the 30" tires are deffinatly helping the 4.10s. Today I was out cruising with the wife and I did manage to get it stall to 3500 and it built boost. When I let it fly I felt much better. That was on the street.
Old Jun 30, 2013 | 03:18 PM
99VetteFRC's Avatar
I found out that I can actually load the converter to 3000 rpm on hte street. It felt like it launched better. Next time I get it to the track I will try some different things.
