Safe and/or possible to drive to the tuner?
So, I'm almost ready to finally put a Procharger on my '00 SS. Question is, once I do the mod(s), will I be able to drive it to the tuning shop (Tick Performance is 40 miles away) with the following mods done all at once?
Note: I'm not holding anyone to hard facts...just looking more for past experience under the same circumstances.
Installed Now:
1. BBK 1-7/8" Longtubes - NO Emissions.
2. EGR Deleted
3. Currently have an SLP Tune Flash, but obviously I'll remove that before installing the blower.
Installing:
1. Seimens 60lb injectors.
2. 255/hr Pump.
Note: We have 93 Octane w/ or w/o Ethanol around here, not 91.
3. Procharger P1SC1 Kit w/ 4.5" Hi-Flow Twin Intercoolers. Shooting for an 8psi setup with a 6-rib and 3.2" pulley.
4. Boost Limiting Valve set to 9 psi mounted near the bypass.
I've heard a couple people say on other threads that it's not possible to drive with an injector swap before a tune. Is that true?
Any advice would be appreciated. Rollbacks can't access the area where the install will occur, and if trailered we'll need a winch to pull the car uphill out of the garage.
with the 60 #injectors and procharger both installed before my turner did some changes to the tune
just my .02' Johnny
ps if you must push it up hill,I would go to Haber Freight/or some like supplier and buy/rent a cheep wench
Best option is to send them the computer and have them flash a base tune in there and then you can have everything installed ready to go for the drive there.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Do not install the injectors until the car is at the shop. You will run the risk of washing down the cylinder walls and tearing up piston rings due to lack of lubrication. Put them in in the parking lot there is only 4 bolts and will take you 5 min tops.
just my .02' Johnny
Thanks for the compliment on my car, Johnny! Yours looks sharp as well! Silver or black, or silver AND black are the way to go IMO!
Thanks to EVERYONE for the advice!
After the install, I'll probably start it up to see what happens, but I'll definitely leave the injectors off until I get to the tuner.
Everything except the 60lb Injectors, 2-Bar MAP Sensor, and the MAF-less piping from the plenum box to the TB is FINALLY installed! (I will install all that once I arrive at the tuner.)
So....I took it for it's first test drive today and it ran fine. My ONLY concern is that my AEM wideband is showing an A/F ratio of 16+...even at idle. Is this normal for pre-tune numbers, and is it still safe to drive?
(Note: During the test-drive, I never once got into boost, but I also noticed that the A/F ratio actually DECREASED when I gave it more throttle?? Down into the 14's.)
Advice/opinions?
