Cooling issue D1 T/A
Make sure your air splitter plastic flap thing a muh jig is on on the bottom.
Bleed the air out of the radiator using some sort of special tool. PM alchemist about it and he can point you in the right direction.
Add an additional spal fan, and make a shroud for the radiator.
Add straight water and use some additive. that usually helps 5-10*
Are you running a/c? alot of people say it spikes when that is on.
If you are running dual intercoolers instead of an FMIC then thats also an issue.
It takes a little time and effort to get her to stay cool. Don't get frustrated. Just keep trying till you get it working right. Good luck.
A dirty AC condenser restricts airflow to the radiator. Check it - it must be perfectly free of debris.
The AC condenser radiator fins are notorious for plugging with debris almost a third of the way up from the bottom especially if it has never been cleaned since it left the assembly line.
It order to get 100 percent airflow to the radiator, you must get 100 percent airflow thru the AC condenser because most of the air getting to the radiator passes thru the AC condenser first. Plug the AC condenser and you reduce not only the efficiency of the AC condenser but the radiator as well.
Obviously, you want to make sure the fins on the radiator are completely debris free as well.
So even though are you NOT currently using the AC - if the AC condenser is plugged, it's causing a restriction of airflow to your radiator.
Double-check the steam vent hose and the radiator overflow hose. Sometimes in the haste to button up the job the hoses get flipped.
I don't think it's the Procharger causing the issue, it's easy to check though, just pull the belt or leave open the bypass valve. Without it generating boost, it's not adding all that much load on the car cruising around, at least not enough to cause overheating.
When you say overheating, what temperatures are you seeing? 220 is ok in my book, at least for stop and go traffic with a/c on in the summer heat.
For reference, I rarely ever go above 200-205 degrees, and that's with a/c on in the summer heat. Stop and go isn't too bad for me since it's not driven in the city, just back roads.
