Stock bottom end lq9 930whp 17psi 91mm garrett
#62
I took the car to the track back in August ran a 9.8@151 blowing the tires off to the 1/8. The track kicked me out said not to come back unless I get a cage. I Went to another track in November and took out the thrust bearing on the crank so the motor is getting forged up.
#63
#72
When I was on the trans brake it was building too much thrust pressure in the converter causing the crank to be pushed forward.
The place that built my trans didn't restrict the converter feed in the pump as u can see in the pics.
