Griffin radiator guy with turbo,ac,auto. step in for the end all cooling solution.
With that comp 88 I'm assuming that's probably a t6 medium or large frame? How close is your turbo to the fans? I'm considering this for my future 370 front mount s480 build. Curious how those fan motors will stand the test of time with the heat off of that hot side so close. Mine would be set up basicly the same way.
Its a midframe t4, similar to a pt88. I run a really thick turbo blanket. It actually rubs up on the fan housing. If I took it off i have about 3/8inch clearance. Ive had these on for 2 years.
