iat sensor reation time
Old Jul 19, 2013 | 04:38 PM
bct10985's Avatar
Default iat sensor reation time
I have a 2010 camaro ss ls3 and Since i have bought the caspers iat breakout harness and installed a 2002 camaro ss iat sensor in front of the meth nozzle i have noticed on my ultraguage that the iats dont jump around as much as before like they are slow to react to changes? I have read that the threaded ones u can buy say "fast reaction" sensor for forced induction. Like this http://www.diyautotune.com/catalog/g...tail-p-62.html . Is that true and are they the same as the gmc cyclone sensors u can pick up at a local parts store. The reason im asking is if i get it tuned for meth to pull timing if it fails and iats go up u obviously want a iat sensor to react as quick as possible.
Old Jul 19, 2013 | 05:19 PM
zapp109's Avatar
when you say in front do you mean the IAT is before the meth nozzle?
Old Jul 19, 2013 | 07:28 PM
bct10985's Avatar
No sorry bad wording. In order maf, then meth, then iat, then throttle body.
Old Jul 20, 2013 | 11:39 AM
bct10985's Avatar
I just wanted to know if there really is a difference in a push in type iat and a so called "fast response" screw in type. Guess ill just have to try one for myself only like 20 bucks.
Old Jul 20, 2013 | 03:59 PM
stevieturbo's Avatar
If your sensor is an open bulb type thermistor, then generally it is deemed a fast response.
But it will never be like milliseconds response.
Old Jul 20, 2013 | 04:35 PM
bct10985's Avatar
The stock one that is in the maf would change every second or so. This new one seems to only change every 10 seconds.
Old Jul 21, 2013 | 01:00 PM
bct10985's Avatar
Anyone?
Old Jul 22, 2013 | 08:49 AM
bct10985's Avatar
Bump.
Old Jul 22, 2013 | 09:59 AM
bad6as's Avatar
Take it out. Plug the sensor in. Turn the key on. Start the scanner and watch iat. Then take a heatgun and blow across the sensor while watching the scanner
