Best Air to Oil Separator Catch Can?
Old Jul 30, 2013 | 09:08 PM
Forcefed86's Avatar
Originally Posted by CameronVic
I guess my next question is where did you get that?
Jegs/summit sell them. Exhaust evac kit.
Old Jul 31, 2013 | 08:28 AM
MIGHTYMOUSE's Avatar
should still run a catch can, likely you are pumping oil across your oxygen sensor.
Old Jul 31, 2013 | 09:35 AM
Forcefed86's Avatar
Thanks for the suggestion. If I had the evac kit setup properly you’d be 100% correct. Like I was saying above, while in boost, I build up enough pressure in the exhaust that the exh. evac doesn’t pull vac. Check valve just closes. So I currently have the pass side vented into a coke bottle. The small amount of oil residue that builds up in the tubing while in boost will still be pulled into the exhaust like you’re saying when I get back in idle/cruise though.
I did run a can inline at first. Routed some hoses in the can to help baffle and then stuffed it full of copper SOS pads to keep the mist in check. They can was super heavy though, made of some crazy (3/8”?) thick 4” alum alloy stock material. Anyway, ran it that way for alot of street miles and the can always had water only in it. It was nice, but I couldn’t justify the weight and ugly lines running all over so I pulled it. (Still have it if anyone is interested $30 shipped)
I did order 2 light weight, thin wall, alum 750ml cans for each side. (or maybe in series) Once they get here, I’ll build up some baffles and a vent and run them both with the new straight 4” downpipe. Should pull vac under boost then.
Hey mighty mouse, would it be advantageous to run an inline check valve (PCV valve) with the filter on the top of the catch cans? That way you would have a sealed system pulling a much higher crank case vacuum under idle and cruise? Then under boost the cans could still vent?
Old Jul 31, 2013 | 11:04 AM
a pcv valve is a check valve in one direction, and a flow regulator in the other.
if you are talking about hooking to the intake, then you are talking about the normal way to get pcv, and the way my cans are set up.
except if you just put an open element on the top you will lose all your vacuum to the breather... at this point i would driect you to my sig
Old Jul 31, 2013 | 11:31 AM
Forcefed86's Avatar
I get how your system works and what a pcv valve is/does. (nice website BTW) Most PCV valves weren’t designed for boost and leak. Turbo guys have been replacing them with a decent check valve of some sort since the 80’s.
The exhaust evac kits pull a tiny amount of vacuum compared to a system plumbed into the intake or turbo inlets. (usually like .3-.5inhg) So they have issues pulling through any kind of restriction. (pcv or check valves in the stock location) So if I put the can inline with my exhaust evac and a check valve under the filter on the can it wouldn’t cause any restriction in vac but would still allow boost to vent out of the crank case if the exhaust evac couldn’t keep up.
Old Jul 31, 2013 | 12:38 PM
thanks, not bad for a freebie site.
the pcv valves i use seal in boost. anyone who replaces a pcv valve with a check valve now has nearly unregulated vacuum going to the crank case, will likely have related problems like transferring oil to the intake, or more than before, and a squealing sound as air enters the engine via front and rear main seals or similar.
I ran a check valve in line with my pcv valve until i finally found one that suited both needs.
you can definitely hook exhaust vac and intake vac to the same can. I would make sure the fitting on the exhaust can handle possible suction from the intake side without leaking / allowing exhaust to come into the can / intake
Old Jul 31, 2013 | 01:58 PM
CameronVic's Avatar
not if you put it after your 02 sensor.
Old Jul 31, 2013 | 03:31 PM
i was responding to the guys specific picture, not for everyone, all over the world, in general
Old Jul 31, 2013 | 05:11 PM
CameronVic's Avatar
I know! I was just being silly
