using helicoiled block for boost.
Old Jul 24, 2013 | 05:07 AM
badazz99ss's Avatar
Default using helicoiled block for boost.
Hey wussup guys im about ready to start my turbo build. I was tossing around the stock 5.3 motor or using my forged 347 that needs rebuilt. The block has 1 headbolt hole that is helicoiled. Will this be safe to boost or should I grab another 5.7 block to put the rotating assembly in? Will be shooting for around 900rwhp
Old Jul 24, 2013 | 06:59 AM
DEFYANT's Avatar
LS1/6 block is not thay great for boost to begin with. Slam that Rotating Assemble in the LM7 block.
Old Jul 24, 2013 | 08:58 AM
Inspector12's Avatar
TT-TECH Veteran
Nothing wrong with a helicoiled head bolt. Usually they are stronger than the threaded block itself.
Old Jul 24, 2013 | 09:16 AM
LT1RAY's Avatar
Time Sert makes a nice head bolt repair kit for LS blocks if you wanted to redo it.
Old Jul 24, 2013 | 12:57 PM
badazz99ss's Avatar
Hmm I didnt know that. just didnt want to lift a head.
Old Jul 24, 2013 | 12:59 PM
Ferocity02's Avatar
It will probably be fine, but I would use studs to reduce the stress on the helicoil.
badazz99ss's Avatar
I just might have to look into that. Thanks man
Old Jul 24, 2013 | 11:53 PM
Blown06's Avatar
8 Second Truck Club
Why would you wanna redo it?
Like said above, helicoil can be stronger than a regular thread anyway.
Old Jul 25, 2013 | 02:09 AM
LilJayV10's Avatar
Old Jul 25, 2013 | 03:51 AM
itsslow98's Avatar
I agree with you lol, but i also believe the aluminum LS1 block isnt the best choice for 1,000+ crank hp like the OP is aiming for.
Old Jul 25, 2013 | 11:29 AM
badazz99ss's Avatar
Tjanks guys. Well now u got me thinking with the aluminum block at 1, 000 hp mark. Hmm I think im going to let er eat and see what it does. Build thread coming soon. Thanks fellas
Old Jul 25, 2013 | 11:27 PM
TT-TECH Veteran
I've never used anything but aluminum blocks and been making over 1K at the wheels for a LONG time on all different size motors. And next they will be telling you that you can't do it with out a 6 bolt block etc... But Ive never owned one of those either. GL! Pick your parts well and you will be fine.
Old Jul 26, 2013 | 12:03 AM
itsslow98's Avatar
We all have our opinions and like I said the ls1 block will work, but is it really the best option when your gonna put that klind of money and power into it? Iron blocks are a lot more stable then aluminum its proven.
Dont get me wrong I just built an aluminum block for my cobra instead of going with another stock iron block like it came with. I took the 70lbs of weight savings over the stability of the iron block because i wont be pushing it quite that hard.
Old Jul 27, 2013 | 06:43 AM
badazz99ss's Avatar
I would put the rotating assembly in the iron 5.3 but being it would have to be bored out to a 347 what would be the point being the walls wouldnt be thick any longer.
Old Jul 27, 2013 | 08:16 AM
DEFYANT's Avatar
facepalm
Shove your facepalm up your ***. For what the OP is aiming for the LS1/6 block would be an issue.
I was reading over Fireballs thread yesterday, and one of the post was that Shawn from VA. Speed saying that he stripped out a head bolt thread in the RHS block, and that he was going to Helicoil it. Apparently it worked LOL.
Old Jul 27, 2013 | 11:17 AM
Krom's Avatar
why not open up all the holes for 1/2" studs, and kill 2 birds with one stone?
