what head gasket to use????
Old Jul 29, 2013 | 11:01 AM
s10_ls1's Avatar
Default what head gasket to use????
i have a stock bore ls1 i know i have to run an ls2 head gasket due to the heads i went with from TEA but just gathering thoughts of what ones where best to go with for the supercharger ''maggie'' and the nitrous any thoughts would be great thanks
Old Jul 29, 2013 | 11:21 AM
conan's Avatar
What size combustion chamber does your heads have.
Old Jul 29, 2013 | 12:29 PM
denmah's Avatar
Moderator
if its 5.7 or smaller you can just run 34 dollars for the pair, of ls1/ls6 head gaskets from summit, they work awesome
Old Jul 29, 2013 | 01:07 PM
s10_ls1's Avatar
the combustion chambers are 71cc they are the 225cc trickflows from TEA they went through and did there tricks to them for boost and also got the nitrous exhaust ports as well
Old Jul 29, 2013 | 04:28 PM
conan's Avatar
Go with some GM - MLS for the 6.0L.
Old Jul 29, 2013 | 05:51 PM
Blackpanther99's Avatar
6.0 head gaskets as mentioned already.
Old Jul 30, 2013 | 10:52 AM
s10_ls1's Avatar
thanks for the input guys
Old Jul 30, 2013 | 01:33 PM
willizm's Avatar
I run those on a stock bore ls1 using 317 heads and haven't had issues. I heard folks were using the ls9 gaskets from a year or so ago. Not sure if that would be a better route to go or not. More layers of steel.
