Boost control using one WG on a twin scroll setup
Old Aug 8, 2013 | 10:39 AM
69-chvl's Avatar
Default Boost control using one WG on a twin scroll setup
Just curious if anybody ever just vented one side of a dual scroll setup and was able to control boost effecttively.
Old Aug 8, 2013 | 11:29 AM
TurboJoe@Straightline's Avatar
That's a odd one, I would just run a mini merge from bank to bank to your gate
Old Aug 8, 2013 | 02:29 PM
stevieturbo's Avatar
it may work, but would be a very bad way to do it.
If you insist on using one w/g, at least run two pipes and them merge them with a divided Y into the gate, so both sides are kept separate right up to the gate.
But as a V8 wont be true twin scroll in the normal sense in the first place....keeping them divided probably isnt as important as a 4 cylinder
3pedals's Avatar
I run 2 40mm gates, 1 in each side of the divided hot side.
Costs more for the second gate, but seems to work flawlessly
