My twin 66/408 Straightline/Turbo Joe build
Old 08-13-2013, 04:21 PM
phatasp's Avatar
Default My twin 66/408 Straightline/Turbo Joe build/PROJECT UPDATE AND WARNING
I,ve never done this kind of thing before so be gentle. I recently took my YSI supercharged WS6 to Straightline for a little bit of work and a tune, after walking around the place and seeing all the badass turbo builds and talking to Turbo Joe I figured it was time for a new kind of boost. here,s a couple of pics from before with the YSI and some of the stuff Turbo Joe has fabbed up for me.(this guy can weld) I,m going to miss the YSI but I,m pretty excited to see this come together.
After about 14 months my car finally went on the dyno And as soon as it 5000rpm it proceeded to self destruct, so out came the motor again and sent to PER race engines where it was discovered to have had the cam installed 1 tooth off and pretty much wiped out the block the heads and of course a couple of the pistons, So now we're going with a Darton sleeved LS3 blocked 416 with AFR 245 heads. And now the warning, I bought this motor from a guy on this sight guaranteed to be in perfect working order, well it definitely wasn't, it only had idle time prior to being put on the dyno. Not only that, almost none of the parts he claimed that was in the motor are. So all in all I was able to use the Callies Comstar crank(not the dragonslayer) that was claimed and the Howards rods ( not the Callies H beam rods that was claimed) Now after that long I'm not asking asking for anything(because I know I,m not going to get it) All I want to say is that if you buy a motor, trans or anything on here or any where don't be a dumbass like I was, get a build sheet and VERIFY,VERIFY, VERIFY. Anyway my new motor is done and the car should be ready to rock very soon.
looks like I might even to be able to get to the plugs
Old 08-13-2013, 04:46 PM
willizm's Avatar
So much win!!!!
Old 08-13-2013, 04:49 PM
phatasp's Avatar
Thanks, those guys are great to work with.
Old 08-13-2013, 04:56 PM
DEFYANT's Avatar
Sweet! What are the specs on the rest of the car? What turbos?
Old 08-13-2013, 05:28 PM
phatasp's Avatar
I believe their turbonetics 6668 turbo,s
Short Block:•GM LS2 engine block with 4.035" bore
•Callies Dragonslayer 4.00" stroke
•Callies Compstar H Beam connecting rods
•ARP main studs
•Custom Diamond Pistons Teflon Coated skirts and Ceramic Coated tops(9.4:1 compression)
•Double Roller timing set
•Ported GM oil pump
Top End:•Dart Pro 1 225 as cast cathedral port heads
•PAC 1521 Dual Springs with Ti Retainers
•House of Boost custom ground cam
•GMPP LS7 lifters
•Comp Cams push rods
•GM stock LS2 rockers with Comp Cams trunion upgrade kit
•ARP head studs
ported by vengeance Fast 92 intake
RPM level 7 trans
9in. rr currently with 410s putting my 3.50s back in
Old 08-13-2013, 05:30 PM
phatasp's Avatar
Oh, and some REALLY ugly valvecovers
Old 08-13-2013, 05:39 PM
TurboJoe@Straightline's Avatar
O c'mon man there custom!!!
Old 08-13-2013, 05:40 PM
willizm's Avatar
I want to have real ugly valvecovers too but I ain't got no love from straightline
Old 08-13-2013, 05:42 PM
DEFYANT's Avatar
I was going to be nice and keep quiet about the valve covers lol. Those turbos should light off on a 408. Good luck with it man.
Old 08-13-2013, 05:47 PM
All was on perfect track last night till i drank a rockstar, my hand got a little shaky.
Old 08-13-2013, 05:50 PM
phatasp's Avatar
Thanks, should be really interesting
Old 08-13-2013, 05:58 PM
phatasp's Avatar
Damn, I would have ZERO patience for that
Old 08-13-2013, 06:02 PM
Blackpanther99's Avatar
Just wow
Old 08-13-2013, 06:39 PM
allout06's Avatar
Makes me wanna start over
Old 08-13-2013, 06:51 PM
konceptracin's Avatar
Joe is the best hands down! You will not be disappointed with product or customer service from any of the guys over there!
Old 08-13-2013, 07:32 PM
Dont do that! Lol Leave it as a future option
Old 08-13-2013, 09:11 PM
jt76's Avatar
Joe does it again!
Old 08-13-2013, 10:13 PM
jt, theres 3 other builds i wanna show too but cant you seen the one on instagram
Old 08-13-2013, 10:51 PM
phatasp's Avatar
I agree,Allout, thats a badass build you have going!
Sold me
Old 08-13-2013, 11:10 PM
Lol sorry buddy we have been swamped! I wish you kmew!!! swing by some time well talk about getting that gear in.
Quick Reply: My twin 66/408 Straightline/Turbo Joe build
