Fuel system help..
Old Aug 23, 2013 | 04:18 PM
  #41
Forcefed86's Avatar
$134 each shipped to your door.
http://www.ebay.com/itm/WALBRO-E85-RACING-FUEL-PUMP-F90000267-450LPH-IN-TANK-W-INSTALL-KIT-/321035314959?pt=Motors_Car_Truck_Parts_Accessories&hash=item4abf32270f&vxp=mtr
Old Aug 23, 2013 | 04:45 PM
  #42
allout06's Avatar
Will those fit in a factory bucket? Any modding needed?
Old Aug 23, 2013 | 10:39 PM
  #43
wicked z28's Avatar
Curious as well if two will fit in the fuel bucket.
Old Aug 23, 2013 | 11:31 PM
  #44
allout06's Avatar
If the measurments in the ebay add are in mm, the base is about 2" in diameter and about 5" long. Ill have to measure my bucket to see if theyll fit.
Old Aug 23, 2013 | 11:50 PM
  #45
wicked z28's Avatar
Keep us posted on your findings.
Old Aug 24, 2013 | 12:05 AM
  #46
allout06's Avatar
Will do
Old Aug 24, 2013 | 11:43 AM
  #47
Forcefed86's Avatar
denmah put two walbro 400's in his oem truck "bucket". 400's are the same dimensions the 450's are. Not sure if the truck bucket is larger though.
I wouldn't suggest plastic or brass fitting with ethanol either....
Old Aug 24, 2013 | 08:47 PM
  #48
allout06's Avatar
They look very similar. If I have time ill pull mine out tomorrow and measure it. Im really considering this route. It looks like itll save me about $450. If I read the wiring right, I should b able to plug my stock harness in and remove the tan trigger wire from the plug and run it to the relays. My battery is being located to the rear so wiring it up will be pretty simple I think. Where can I get some non -AN y blocks?
Old Aug 24, 2013 | 09:26 PM
  #49
TT402LS1's Avatar
Im setting up my fuel system now too. Good info here! Has anyone run a Kenne Bell boost a pump? I was thinking one Walbro 450lph and a bap. I like the idea of one pump. If it fails your engine quits running. With two, if one fails, you could go lean and hurt something. Anyone here running a bap?
Old Aug 24, 2013 | 10:09 PM
  #50
allout06's Avatar
i think a BAP could fail just as easliy as a pump causing the same issues. Long as you have a wideband and a fuel pressure guage, you should be ok, you could also wire in a light letting you that the pump is on. Im not too worried about a failed pump to be honest.
