Help me pick new TT LSX engine size
All that said I really feel anything much over 390" is going to be capable of more power than will get utilized. The all so common 427 build is too large and will have back pressure issues with even 6766 turbos.
Although I don't want to spend a **** ton of money on(unnecessary upgrades) I do want a put it in and forget about breaking it combination. Therefore I really feel a LSX, Dart Hybrid, or ERL superdeck I 6 bolt block is necessary, for the larger bore (unshroud the vavles) and thicker sleeves. I intend to run my existing LS9 4 bolt heads and std ARP studs until head lifting becomes an issue.
So after this long winded post what is the opinion of those with experience near this level? Is the 6 bolt block a necessary expense at this level? 3.62 stroke or 3.80 stroke? Best engine shop for the money? (I've talked to LME, AES and PM's from ERL) So far I'm leaning toward LME because of their dedication to the LS platform and price. I hate to add 20-30 lbs for the LSX or Dart block, the car scales 49.7f/50.3r now with me in it. Another issue I'm concerned with Callies Dragon Slayer cranks is a couple of local guys have had 4" stroke cranks flex and wiping out the thrust bearing and I've heard issues with welded on reluctor wheels coming off and/or not being clocked correctly. Advantage that I've heard from ERL is an exclusive from Callies with a wheel machined directly into the crank.
Prices on a 388 6 bolt short block have ranged from $8500ish to $9500ish vs around $3800-$5000 for a 370-390 4 bolt factory block build (big price difference).
I know several of you guys have seen the car in person and I really appreciate the comments. We will be at LS fest in Bowling Green, Please introduce yourselves as Bullet members if you are there.
Just to correct what you heard, we use a billet reluctor that is still pressed on (not machined into the crank), but eliminates the possibility of separation.
Also we offer a 3.900" stroke crank with 2.200" rod journals that increases crank overlap to make it more stable as you mentioned. Callies makes an ultra billet rod for us with the BBC big end to run the larger bearing.That would put you at 416-417" with a 4.125" bore and offers better compression height as you mentioned. The 387-388" would be safe on the 6766 turbo's at high RPM's.
The big motor would be more fun on the street because it would be on boost sooner, but the small engine would handle the High RPM's at the track without back-pressure coming into play. It depends on which you do the most.
Cam, lifters and springs are going to be key to living up to the street miles and the boost /RPM's to run high 7's, so don't do budget there. I'm working on a similar build for a customer, but cheap wasn't in the build. I tend to overkill and told him that it's capable of better than his goal of 7.50's on a 106mm though.
My $.02.
Maybe we miss understood but we remember talking to one of your guys at LSX shoot out in Indy last year about a 275x car we work on. 427 LSX block, dragslayer crank deal that kept wiping out the thrust bearing. We thought your guy said you have an exclusive on a crank from Callies that has bbc journals and the wheel machined directly into the crank, eleminating the 2 major problems with these FI 4" stroke combos, crank flex and the wheel coming off.
I don't really feel I need to upgrade my turbos to run very low 8's. maybe to run 7.90's. I really want and engine sized (and keep the cam timing in the mid/upper 220's) to match my existing turbo/intake set up as there is a LOT of work that has been put into it.
Stay away from the 98-2000 blocks. Mainly you will want the equal length head studs( LS6/ gen2 ) of the early blocks. We can't do a dry sleeve on the LS1,LS6's but we can do the superdeck which yours would be to go 6-bolt.
I hope to see you at the Holley Fest if you get a chance to stop by.
I lean more towards the 410 cube that AES makes being that it is a bigger bore which can utilize bigger heads, LS7, LSW etc.
You mention unshroud the valves. You have a boosted application which kinda takes that out of the equation.
As far as LS1 block for re-sleeving. the 5.3L aluminum blocks are going on here for 300-500 all day. They are a better choice in my book. I just picked up 2 of them recently for 300 a piece.
The car has been 9.09 at 147 already. I want an engine that'll go 50,000+miles, make 8.50 passes anywhere and not worry about breaking it 500+ miles from home.
6.4 (390 cu in) + ~19psi =1000hp
Boost breaks ****. 390 cubes will be more reliable all day. A 427 would be even better but the OP doesn't want to change turbos so somewhere in the 390-410 area is where he needs to be.
This engine has rectangle port heads on it already, the intake manifold has an air to water intercooler core built into the manifold base. It takes about 2 talented guys 2 hours to put the intake on with all the **** underneath of it. This is not a Sloppy Mechanics build, and while truck manifold systems can make a **** ton of power this is not one of those (the engine hiding in there now went 8.15@172 in a different car with truck manifolds).
I'm not cutting and hacking anything under the hood of the car. It has 6262 Precision v-band turbos that should support 1400 hp on a 388 and 6766's are a drop in replacement for a conservative 200-250 hp gain. I'm not some punk *** kid, I know what I'm doing as does Blake Hughes of 417motorsports who fabbed the hot side, cold side, manifold top, I/C and pretty much everything else under the hood of this car.
http://www.flickr.com/photos/99969026@N06/9454163761/
I came here looking for intelligent from experience engine builiders sure as AES, LME, Shawn @ Virginia Speed, ERL who for whatever reason won't call me. I want an Extreme duty street engine that I can run for 5-10 years and not take the valve covers off of. This is not the car for putting junk yard motors in and blowing the **** out of them.
http://www.flickr.com/photos/99969026@N06/9454189337/
That's Joe Barry's 200+Mph 6 second 56 Chevy behind my car at Gus's Drive-In and here's what he had to say on Yellowbullet:
"This is my favorite car I saw the whole weekend. I kept sending people over to take a look because to me it was the coolest. I'm not good with names however the gentleman and his son as well as his girlfriend were great people to talk to. They built this car to what they like and it's kick ***. The next car I build is going to be alot like theirs , it just oozes cool and it runs damn good."
I'm never selling the car, it's exactly the way I wanted to build it and I want an engine that I can put in, beat on hard and not break it.
1300hp is easy to do all day on an engine dyno. Put that setup in a 3700lb car and watch what all the drivetrain weight does to that thing.
If you want to use a 5.3 in your setup, then by all means do so. In this car is not a practical solution.
Livernois did my shortblock. They maybe a good one to talk too.
