Pegged the Dyno and Picked Up 300rwhp with LJMS CAM
thanks guys 25+ psi scares me
its still a 370inch with a tick over 10:1. Nothing special here if you have the time and a couple nickles to build it... it can be duplicated
I peeled the plasti dip about a month ago, it wasnt for me or the car...cool experiment thats all. Hopefully getting the car painted this winter.
Changing the oil and going over some things on the car today and getting ready for tomorrow. Weather has been nice up here with good air quality, if I get it to stick on a soft launch here at my home track it should be a good run.
oh, i see. I like the red better anyway.
good luck at the track today.
You can't estimate power gains from boost levels. You have to use fuel flow. Boost with a small cam will be significantly higher vs a larger cam.
Like on a blower car, swap cams, boost decreases. You don't add a smaller pulley to bring boost back up, then claim the power numbers from just the cam.
#33
yes some worked all pro 4 bolts
yeah for the moment, when I change intercoolers I will step it up
its sucks but the head is not bad, chris razor is fixing it and ill be back next week at the track hopefully on saturday
