On3 Turbo kit been searcing for days for answers
Old 09-11-2013, 08:15 PM
tcamaro98's Avatar
Default On3 Turbo kit been searcing for days for answers
Have been searching for a few days and cannot find anything on there kit as it setup from them.. how many #s are you getting from it and numbers...im looking at this kit as opposed to going H/C again any info would be great..ive learned I can bolt a kit on and go but is this a good kit or would a rear mount be better
thanks for the help
Old 09-12-2013, 04:06 PM
gpr
gpr's Avatar
Its a descent kit expecially for the price. You will be able to make more power then you would with head and cams any day. How much power you make depends on how much boost you want to run.
The turbo kit will make more power but will be more expensive in the long run, as the kit comes with a lot but not everything. still need a fuel pump, regulator, larger injectors, air filter, exhaust, map sensor, fans etc...
Quick Reply: On3 Turbo kit been searcing for days for answers
