whats a good budget friendly e85 compatible fuel line
Old Sep 11, 2013 | 11:36 PM
baggins's Avatar
Default whats a good budget friendly e85 compatible fuel line
What are you e85 users using for fuel line? My car is stripped and ready to be plumbed for fuel just need some insight. Thanks!
Old Sep 11, 2013 | 11:43 PM
WheelsUp84z's Avatar
i use the ptfe braided stuff from here: http://www.anfittingsdirect.com/ ive done 3 cars with their stuff.. no issues and can do a full feed and return setup for about 375 bucks
Old Sep 12, 2013 | 12:00 AM
Ferocity02's Avatar
PTFE holds up to darn near anything. I use it for brake fluid and methanol.
Old Sep 12, 2013 | 01:25 AM
95bowtie's Avatar
I personally used the black aero quip push lock hose. Been two years with e85 sitting in them and they are like new inside and out.
I know the inside is still perfect because I changed my crossover setup on my rails and they looked perfect inside still.
That's about as budget as it gets, everything else is pretty pricey if your talking "budget"
Old Sep 12, 2013 | 05:03 AM
samdogmx's Avatar
http://www.ebay.com/itm/230397537751...84.m1423.l2649 as cheap as it gets
I have also used the jegs brand lines
Old Sep 12, 2013 | 08:44 AM
2muchboostNY's Avatar
Whichever route you go make sure to get PTFE if you plan on letting E85 sit in the fuel system for any prolonged period of time. Some people near me have gotten lucky with the non-PTFE lines but others have degraded the internal material of the lines.
Old Sep 12, 2013 | 09:51 AM
turboventura's Avatar
I've had regular jegs AN rubber line on there for 2 years, had e85 in it the whole time. No problems so far.
Old Sep 13, 2013 | 06:29 PM
Reject's Avatar
just make sure that the inner lining has a black coating on it. it is to prevent any static discharge on fuel lines.
Old Sep 13, 2013 | 10:00 PM
LS1RedZ's Avatar
I got my fuel line setup from nitrous outlet. If u know exactly what you need and the bends they can press them on. But you have to be exactly sure of how u want it and the measurements.
Old Sep 14, 2013 | 09:50 PM
2JZFC's Avatar
Aeroquip AQP push-lock. It is synthetic rubber and 100% E-85 compatible.
