Finally got the SS to the dyno for some numbers :)
Old Sep 16, 2013 | 08:49 PM
Detoxx03's Avatar
Like how quick the turbo spooled.
Old Sep 16, 2013 | 08:57 PM
607motorsports's Avatar
I trailered the car because the dyno was over an hour each way and planned on beating on the car pretty good on the dyno so better safe than sorry.
The turbo hotside is a PTK kit that I bought from a member on here a couple years ago who had never used it. I modified it a bit to work the way I wanted it and me and a buddy built the cold side. I don't have any pics of the actual turbo setup just an engine bay shot.
Old Sep 16, 2013 | 09:09 PM
No track times yet hoping to make it to the 1/4 track before it closes this season. Unfortunately I live in an area where nothing is all that close
Old Sep 17, 2013 | 11:20 PM
Fondle's Avatar
what are the cam specs?
Old Sep 17, 2013 | 11:40 PM
allumini's Avatar
he said he is using a Tick stage 2 Cam
http://www.tickperformance.com/tick-...r-ls2-engines/
Old Sep 18, 2013 | 01:17 AM
cmurphy9900's Avatar
Sick car man. I can't believe that's on pretty much stock internals too. Definitely got some needed motivation from watching this.
Old Sep 18, 2013 | 01:32 AM
denmah's Avatar
Moderator
impressive on a in tank 340 and stock lines and 60lb injectors for sure
i wonder what this car would trap
Old Sep 18, 2013 | 02:29 AM
Tirefire's Avatar
Stock regulator? What the the hell?
Old Sep 18, 2013 | 02:48 AM
HUGGER ORANGE SS's Avatar
Very nice car! sounds like you spun the tires there on the dyno.
Old Sep 18, 2013 | 09:13 AM
Major fuel system overhaul coming this winter as this setup is definitely maxed out. Looking to build a fuel system good to well over 1000whp to have plenty of room to grow once a forged motor goes in.
I'm not sure if they spun or not on the pull in the video but they definitely did on the next pull as we rolled into it alot harder. Made a bit over 640wtq on that pull but tires spun so hp dropped down to about 685.
Old Sep 18, 2013 | 09:27 AM
mrstepheneades's Avatar
Originally Posted by 607motorsports
703whp / 619wtq
Man I hope mine gets that kind of numbers in a few weeks. Awesome!!
Old Sep 18, 2013 | 09:47 AM
  #32
S475 @ 16psi man? I think you should def be over 700 What kind of timing?
Old Sep 18, 2013 | 09:59 AM
  #33
35thsscamaro02's Avatar
I don't know if I missed it but what transmission and rear end are you running? Nice numbers!
Old Sep 18, 2013 | 10:01 AM
  #34
14 deg. I'm spraying at ton of methanol to keep it safe my air fuel is 10.2 at 16 psi. It was tuned on pump gas and 8 psi but I bought a wideband an added the methanol and turned the boost up so I'm not sure what I'm making going to find out at Tick performance customer appreciation day. Gonna Dyno then. Mines is stock cam only long block. Heads never been off.
Old Sep 18, 2013 | 10:06 AM
  #35
Stock tranny and stock 10 bolt! Been at this power level for about 2 seasons now I'm not super worried about the tranny since this is not a track car but a rear end is next on the list just trying to figure out which one I want to go with.
Old Sep 18, 2013 | 10:11 AM
  #36
Nice man! My current tune is 18 degrees of timing up top and 11.0 afr. Peak boost is about 15.35psi and 15.0 at 6500rpms. I'm also spraying a TON of meth on my setup, running a dual nozzle Devilsown setup with twin m14 nozzles, 50/50 meth/water mixture.
Old Sep 18, 2013 | 10:23 AM
  #37
Heavy H.P.'s Avatar
Nasty congrats
Old Sep 18, 2013 | 10:31 AM
  #38
I have the AIS Kit with twin 10lb nozzles, pure vp fuels M1 methanol, comes on at 7psi full blast.
Old Sep 18, 2013 | 10:34 AM
  #39
black06g85's Avatar
very nice man, maybe one of these days I"ll actually have a chance to put my car back together and take a road trip.
Old Sep 18, 2013 | 10:40 AM
  #40
Very nice, I would personally mix your meth with water. On the stock block you want the cooling aspect more than the octane benefits to keep things healthy. Being that you're only at 14 deg of timing you def don't really need 100% meth. My setup starts spraying at 6psi so very close to where you're at.
