TBSS makes 801rwhp on E85
Old Sep 19, 2013 | 07:48 AM
dmaxvaz's Avatar
Originally Posted by yelo04goat
how do you like the pump? does ok on e85 at that level? boost ref im sure?
Pump is nice and quiet. It is boost referenced, and has no problem keeping up at that level.
Old Sep 19, 2013 | 09:43 PM
yelo04goat's Avatar
good to know i have the same one and hope to be level but not e85. base pressure 58?
Old Sep 19, 2013 | 10:00 PM
dmaxvaz's Avatar
Originally Posted by Jwilliams04
Wanna get rid of your old injectors
not yet, in the spring maybe
Old Jul 5, 2014 | 04:31 PM
dmaxvaz's Avatar
update on the TBSS: installed a Baker Engineering spec'd cam, some FIC127s, and Tj retuned it. It made 809 rwhp and 801 rwtq @16psi. More power and tq at less boost with the new cam, and power comes in 1000 rpms earlier than before. Then he turned up the boost to 20 psi, and it made 935 rwhp/ 871 rwtq. He stopped there due to the stock tires having traction issues on the dyno and having an aluminum driveshaft (stock). I am very happy with the power #s and with this new cam and retune, it gets decent mileage when out of boost. Tj @ Baker Engineering really did a good job with the tuning.
Old Jul 7, 2014 | 08:20 AM
hellbents10's Avatar
LS1Tech Sponsor
Thanks, I forgot to update this thread when we had it on the dyno last. I bet that TBSS really breaks some hearts on the highway haha!
Old Jul 7, 2014 | 08:44 AM
ablakez28's Avatar
Im running the same pump on my nova which did 888rwhp on gas. Good to see it is cranking some solid #s on E85. I love mine btw. Very nice looking and quiet. I wired one pump to a hobbs switch and I don't even hear them run.
Old Jul 7, 2014 | 03:20 PM
dmaxvaz's Avatar
Haha, this thing really pulls ridiculously hard on the hwy. I ended up getting a steel driveshaft and a strange yoke for some peace of mind. Just need to get some stickier tires now
Old Nov 4, 2014 | 02:38 PM
drifte's Avatar
Nice work, really regretting sticking with awd at this point! btw, whats "decent" gas mileage. You have me curious now.
Old Nov 5, 2014 | 10:56 AM
93camaro_zzz's Avatar
I think the same thing some times. Mine is AWD also. I am thinking it will be a completely different car when I can get a converter in it. How does yours do off the line if you just mash it with that 3200 stall? I was thinking about getting a 3600 for mine.
Old Nov 5, 2014 | 11:54 PM
dmaxvaz's Avatar
Idk, 14ish.
Old Nov 6, 2014 | 07:07 AM
LS1Tech Sponsor
Scott gets about the same MPG on his awd Silverado SS too. He just went 10.4@135 with his truck on E85 with our BEI 370 and a FI 84mm turbo. The track was very cold so he could only leave on 1-2psi or it would spin all 4 tires into 2nd gear.
Old Nov 6, 2014 | 07:28 AM
  #32
dmaxvaz's Avatar
Damn. I need to get that 84mm. Best I could muster was 10.7 @ 131.2 mph, 1.7 60ft pushing through the brakes and 1-2 psi. Tj, I should have bought a motor from you guys.
