~NEW Comp Turbo Standard T4 turbos w/ 79mm Turbine Wheel
It would be nice and we will do it in the future, but it won't give you a clear cut answer. We will test it on one car with one engine, trans, etc. Where as one might out perform another turbo on this set-up, it might not be the same on a different application, however it will be nice info to have! Also I imagine all 3 will perform very similar to one another. The choice in my opinion boils down to brand preference, or what features you want out of the turbo and your specific price point. In my opinion viewing all 3 next to each other, these Comp's take the cake as far as quality goes. This billet wheel, anti surge housing unit is a piece of art
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
We still have these 2 units in stock ready for immediate shipment, contact me to purchase either one
__________________
I have the Billet wheel, polished/anti-surge housing 7679 and the Cast wheel, standard cover 7679 both in stock! PM me for a killer deal!!
__________________
Would work great Frank!
__________________
Billet wheel unit with polished housing is SOLD.
Cast wheel, satin cover is still available. Smoking deal for someone on this IN-STOCK turbo!
We can order these specific to your needs as well here: http://shop.huronspeedproducts.com/C...ger-comp43.htm
__________________
Still have the cast/journal bearing unit! PM me for an awesome price!
Cast 76mm Compressor Wheel
79mm Turbine Wheel
Journal Bearing center
Oil only
.96 a/r
Satin Compressor cover
79mm Turbine Wheel
Oil only
.96 a/r
__________________
Cast unit is sold and shipped!
I have ONE of the following units in stock:
Upgraded Model:
CT43
360 Journal Bearing
BILLET 76mm Compressor Wheel
79mm Turbine Wheel
.96 a/r open housing w/ 3" exit
Anti-Surge Compressor Cover
Polished Compressor Cover
Oil Only
PM me for a SMOKING deal!
Upgraded Model:
CT43
360 Journal Bearing
79mm Turbine Wheel
Oil Only
__________________
Bump for the nice polished, anti-surge, billet wheel unit!
__________________
#32
Bump! Shoot me a PM for an unbelievable deal!!
__________________
#33
7679 on the shelf, in stock and ready to ship! PM me for the best pricing!
__________________
#34
7679 Billet Wheel, Polished cover on the shelf, PM me for an amazing deal!!!
__________________
#35
PM me for a special one-day Cyber Monday price on the following IN-STOCK turbocharger:
CT43
360 Journal Bearing
79mm Turbine Wheel
Oil Only
CT43
360 Journal Bearing
79mm Turbine Wheel
Oil Only
__________________
#36
I don't mean to mess up your thread but Im wondering if you personally have tested these turbos on an ls engine.
Reason I ask, my self and a few others have had horrible back pressure issues especially with the billet comp wheel and 79 turbine.
they switched me out to the cast comp wheel and it helped a lot but it was still done at 5200rpm. Since comp sent me a ct5 with a ct43 cover, 88mm comp 94/88 turbine and that thing rocks.
This was 2 years ago so maybe they changed some thing. Just an fyi if you haven't tested yet, I run a 370 ci.
#38
6.0L, LSA heads. We are investigating on changing the hot side to a 4" with a 4" electric cut out right at the turbo. Right now its the 3" dp. While on the dyno my tuner opened the cutout and gained over 80hp immediately. But this way down the exhaust side close to the muffler ( which is another problem.)
#39
take that muffler off, throw it away ,,, haha only use straight thru muffler . . Im running standard 7879 .96 , made 643rwhp on 16lbs , stock tq converter & th400 ,, prob blowing thru that converter .. and 4.11 gears ,, will be changed in future.. Thats on stock 5.3 with ls3 cam we stoped at 16lbs, cause it was pump gas only , meth kit will be installed next time ., Bout to swap it out for the ly6 , 6.0 l92 heads , see how it does, ill have results in bout 1 month ..
#40
Agree on the muffler, and I have learned a lot lately as I'm trying to soak in a ton of info on turbo setup's. I'm at the same HP level as you on 13psi, once we work out this back pressure issue we will tune for the meth I installed
Are you still running the 3" hot side ?
