Huron Speed Single Turbo Non-AC Forged 347 High Compression E85+Meth Build
Not a ton to report right now since I have been traveling for work and my block isn't back from being cleaned yet.
But when I mocked the kit on my junk motor I noticed the 38mm WG flange did not sit flush with the 38mm - 44mm WG adapter. In the picture below I have it pretty torqued down.
So after doing some reading here and there about possible boost creep people were seeing, although not a lot, due to the extra distance the WG adapter put the 44mm WG away from the cross-over piping, I decided to do a little fabricating. I cut the 38mm flanges off the adapter and the cross-over and welded on the V-band. Yes my welding is ugly, but it was effective.
Next on the list is to wrap the cross-over piping.
I do have a question someone might be able to answer for me though. Since I'm running a speed density tune is there any need to run O2's? Or can I plug those holes? I will be welding in a wide band bung into the down pipe though.
Just a quick update. I picked my block back up and so far have crank, rods and pistons installed.
I ordered my custom cam from Martin @ Tick on Tuesday the 15th. It was on my door step Friday the 18th. Comp is kicking these cams out fast right now.
I also sent my converter off to PTC to be redone last week. Once I get it back I should have everything I need for the build except for a boost controller. I just haven't decided if I want to go manual or electric yet.
LS1Tech Sponsor
Be sure to contact me for the very best pricing on Eboost 2's guys
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Like I stated before, since I had everything out of the car I decided to do rebuild on the motor. So I had the block cleaned and checked and I started to rebuild it last night. So far I have only installed the crank. I plan on doing the pistons, rods and cam tonight.
Here is the block after I picked it up from being cleaned:
Here it is after I installed the main bearings and crank:
Here are the Scat Rods, Diamond Pistons, ARP Rod bolts and not pictured new Clevite bearings that I'll be installing tonight:
I still have not decided what color I want to paint my block. I'm thinking blue like the striped on my car, black, silver or don't paint it. What do you guys think?
#36
I'm still very curious how this thing is going to do given such high compression. With such a high compression ratio, would it make sense to think that you'll need less boost to acheive the same HP/TQ that a lower compression engine would? If this turns out good for you, I may just keep my AI heads and run a turbo setup on my 11.5:1 compression engine.
#40
Should respond very well with that compression.. I have a truck i tune on and it's a 11:7 compression forged 6.2 with L92's with a truck manifold on drivers side crossed over to log manifold on passenger side with a Precision T6 98mm @ 15psi roughly on E85 and it rolls out good for a 2 second ramp time on the Boost Leash.. Truck weigh's 4,600+ lbs and went 9.80's @ 143 on some shake down's first time out.
