Catch Can Routing (Yes, I know it's been covered)
Old 10-09-2013, 01:56 PM
onetype's Avatar
Default Catch Can Routing (Yes, I know it's been covered)
My RX catch can finally showed up after 12 weeks of waiting, and now I'm just curious as to the best routing with my setup. Was running filters as a temp fix while waiting for the can.
5.3
Truck Valve Covers
Ls6 Valley Cover
I'm just not sure if I need to tie all 3 valve cover ports in with the ls6 pcv port to the middle (non valved) port on the catch can.
onetype's Avatar
I have a breather on the oil cap which is why I figured vent the rear port on the passenger side valve cover, and plug the front.
Old 10-10-2013, 09:50 AM
STEEPSS's Avatar
I could tell you the same thing I told you on FB, but......... I wont.
Old 10-31-2013, 11:28 AM
onetype's Avatar
I'm just running it like Tim's right now, with a filter on the extra port. Ideally, it should be routed to the intake tubing pre turbo but I don't want to drill into my silicone coupling.
Quick Reply: Catch Can Routing (Yes, I know it's been covered)
