IAT sensor- which one to use
Old Oct 10, 2013 | 01:09 PM
RB440MIKE's Avatar
Default IAT sensor- which one to use
Which threaded IAT sensor are you guys using for turbo applications? Can you tell me what the thread size is? I need to get a bung welded in and do not have a sensor yet. I will be using a stock GM computer ('04 truck) and tuning with HP tuners if it matters. Thanks for the input. I tried searching but it was not as easy as I thought to find.
Old Oct 10, 2013 | 02:27 PM
JT86SS's Avatar
i use the aem air inlet sensor part# avm-30-2010 at summit racing.. maybe be cheaper one to use but this one has worked for me. comes with bung and pig tail.
Old Oct 10, 2013 | 02:28 PM
Ryans99ls1's Avatar
Do a search for a GMC cylcone or typhoon threaded IAT sensor, thats the one i used.
Old Oct 10, 2013 | 02:59 PM
SPRAYED 01's Avatar
I just used the stock one with a rubber grommit, 20psi. Am I missing anything, thought that's what every one does.
Old Oct 10, 2013 | 04:01 PM
JT86SS's Avatar
Since i used a truck engine, my stock sensor was made in with the maf sensor. So thats y i went with the aftermarket.
Old Oct 10, 2013 | 04:25 PM
Twin turbo c5's Avatar
Syclone IAT's are nice . They are threaded.
Old Oct 10, 2013 | 06:15 PM
T76s10's Avatar
I got mine at napa from a cadillac
Old Oct 10, 2013 | 11:13 PM
janks300's Avatar
gm part# 12110319 is what i used with no problems 20lbs of boost
Old Oct 11, 2013 | 12:48 AM
Blown06's Avatar
8 Second Truck Club
I've got a brand new screw in IAT, with connector pigtail and steel bung. PM me if you want it.
Old Oct 11, 2013 | 01:53 AM
denmah's Avatar
Moderator
pull it out of any v6 gm that is obd2 in the junkyard and hammer it in your Evap solenoid hole after a little drilling = PERFECT!
http://sloppymechanics.blogspot.com/...-in-truck.html
Old Oct 11, 2013 | 08:08 AM
oange ss's Avatar
SU107 (most parts stores part number) thread is 3/8" NPT
Old Jul 11, 2014 | 09:54 PM
MillsMotorvation's Avatar
I also need to know this, I mostly look in the junk yard for the super charged V6 Buicks.
