EEK 22PSI Back Pressure on Rear Mount
Just upgraded from LS1 rear mount to a new LS3 on a rebuilt STS ball bearing 6275 T4 0.81AR turbo and found out why we can't get decent power out of it. The turbine is so small it is creating 22psi of back pressure!
Awesome bottom end and mid-range LOL
But it falls flat up top. Exhaust system is high flow headers into single 3" stainless no tight bends and no restrictions other than 2 x 3" high flow cats - there is no improvement to be had there in flow, it's all in the turbine restriction.
Engine is LS3 6.2L with 218/222 0.561 on 114/116 cam, springs/pushrod upgrades, 040 Cometic gaskets, ARP bolts etc, rpms to 6500rpm max, runs 725cc injectors and twin Bosch 044 pumps.
What would be cool would be to get 2lb by 2500rpm, 5-6psi by 3000rpm and all in by 4000rpm, yet flow enough to make 800hp at 10psi boost.
What sizing do I need guys? The problem I see is getting the exhaust AR right to speed up the spool with a bigger unit yet still reduce back pressure massively.
$50k later and still going
for anyone that can get me to a reliable and good solution here But if you want to persist with the rear mount, ditch the headers and fit factory cast manifolds, heat wrap the hell out of the exhaust system pre turbo, this will improve heat retention and exhaust velocity improving turbo spool.
Replace the turbo with something bigger that will flow enough for your power goals, maybe a turbonetics TC 76 or thier new 7675 using a devided exhaust housing, and add a quick spool valve.
Pressure to turbine is 25psi while the manifold is seeing 6-8psi. That explains why it's been so hard to get boost down to a lower setting even with a big wastegate valve. We're trying to get a low setting of 5psi max but the srping is seeing 25.
The turbo peaks at 12psi in mid range then falls off to 10lb on top end.
When I upgrade the turbo I am going to wrap the entire exhaust first and hope the latest turbos like the 7675 you suggested spool good enough. If not, I guess time to lose the headers, and that'll make me consider moving the turbo up front.... that'll waste a lot of money spent so far lol
The current turbo is only making 510rwhp at 9-10lb boost.
Having large ports with slow moving air is not good on a turbo car. Most builds on here get far too large of hotside tubing. and then complain about spool times, its getting annoying.
Im at work, where yellowbullet is blocked and ls1tech isn't. go figure. so I can't do all your work.
but go search on yellowbullet. Renengade has a post where he breaks down and explains the importance of port velocity.
So, with your "lower restriction" you are hurting your port velocity(ignoring thermal events). Also, the larger surface area of the larger diameter tubing with thinner wall, lowers EGTs which also lowers your port velocity...
Don't expect to have a well functioning rear mount setup by going with "what feels right to me" and ignoring physics and the more experienced.
Besides that. a 62mm turbo is going to pretty maxxed out at 650whp, which is a good thing, but everything has to be working together.
Yes, 22psi/6-8psi ie 4:1 backpressure ratio is very high, but I can't imagine it being your turbo, its not big enough to create those issues. I think its just too small, where are you on the compressor map?
While I respect your viewpoint, spool is not a problem on my set up with that turbo. It could provide positive pressure from a dig even on the old LS1 with nothing but a light brake and a little load to stall the converter briefly. On normal take off it would boost from a stop in under a second - no wrap, totally exposed stainless exhaust. Spool may become an issue with a larger turbo
THe exhaust headers and 2 x 3" system blend via a 2nd collector into a 3" single pipe that makes up the longest section of exhaust, thus speeding up gases and restricting the pipe size to around the same size as the T4 inlet.
THe LS3 spools far quicker and makes so much torque in the mid-range it is actually twisting the trans down and forcing the driveshaft into the loop, so we are having to get stronger mounts and may need to drop the loop slightly. So we are making massive torque, just can't get enough air up top to keep the power climbing.
As you said, the compressor is too small.
I've been recommended an Airwerks S300 BW turbo but would have thought a S400 or BW EFR9180 would be better?
NO idea about my current compressor map - STS did all that figuring out and don't share that info. I can't really read those charts to size right anyway
TTS-UNI-SINGL... Tuner Turbo System Single Universal T4 E-Cover
Turbo 805.00
TC-STS-75-T4E... TURBO STS 75 T4E/T4V P-TRIM BB (67) NO
TURBINE HOUSING 1,745.00
TH-STS-T4V-PT... Turbine Housing STS T4 P-TRIM .81 A/R with
Coating 240.00
I've tried emailing STS but they do not respond, even when asking about buying a bigger unit
Wow,
well if I could achieve that without losing too much bottom end I'd be very happy.
In the meantime I'll enjoy what I've got given the cost to get this far and the turbo just got rebuilt.
They also claim it will spool as quick as the small unit I now have
Sounds like you have a turbo to purchase. That 9180 is an interesting beast...67mm is normally pretty small for a 6.2, but that compressor map has a really fat low end and it is ball bearing... I am definitely interested in the results if that is the turbo you go with.
Interestingly for those that think rear mounts don't have bottom end, my dyno graph comparisons (all same dyno and tuner who is conservative) tell the truth.
Being a 4L60e all pulls are in 3rd gear as it is 1:1
The stock LS1 with headers and cold air intake and tuned ecu made just 100rwhp at 80kph (50mph) - about 2600rpm.
Adding a 222/226 cam and stall converter this moved up to 115rwhp at 50mph.
The same turbo I now have on that LS1 jumped to 210 rwhp - that's an 83% jump!
The LS3 however makes 260rwhp at just 50mph and only 3mph later cracks 300rwhp on same turbo.
Show me a blower doing that on a stock 6.2 motor (well I have very mild 218/222 cam).
