Huron Speed A/C Retain Turbo Kit Blow-Out COMPLETE PACKAGE
Huron Speed A/C Retaining T4 Kit
-Complete package deal, Includes Turbo, WG, BOV, Oil-Lines, Turbo K-member, FREE SHIPPING!
This package special is in stock, and is available to ONLY the first 4 people to purchase!
***Kit has many of the same features as the already successful kit Truck Manifold kit, however obviously retaining A/C with the use of a C6 manifold and a truck manifold combination fitting through a Turbo K-member. Kit will require the use of a Turbo K-member (was built around a PA Racing Super Turbo K-member) This IS INCLUDED IN THIS PURCHASE!!!
For this special package, you must purchase direct from the website here:
http://www.shop.huronspeedproducts.c...-acblowout.htm
Includes:
-Precision 7475 .96 a/r Turbocharger
-XSPower 44mm Wastegate (Silver, Black, Blue, or Red)
-XSPower 50mm BOV (Silver, Black, Blue, or Red)
-PA Racing Super Turbo K-member
-2-piece hotside in 2.5” piping w/ T4 flange and 44mm Wastegate Flange
-2.5” V-band clamp for easy connection of 2 hotside pipes.
-3” 1-piece Downpipe
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-F-body front mount intercoolers brackets
-F-body alternator & tensioner relocation brackets
-Hardware to mount Turbo, intercooler brackets, intercooler, alternator & tensioner relocation to vehicle
-Oil Feed and Drain Line kit w/ fittings
All In the Special have been SOLD!
YES, This Special Package includes the Precision Turbo, XSPower 44mm WG, 50mm BOV, Oil Line Kit, AND PA Racing Super Turbo K-member!![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
All piping made from 321 stainless steel, fully polished.
Advantage of using factory GM manifolds, no fear of aftermarket headers or manifolds cracking due to the turbo weight!![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Advantage of having the Huron Speed customer service!![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Requires Pusher Fans, Misc Hardware, passenger side Truck Manifold to use on drivers side, a passenger side C6 Manifold to run on the passenger side to complete, and lowering or removal of front sway bar
Huron Speed
Kit shown as you will receive it less the oil lines not pictured (You can select the color of your Wastegate and BOV and turbo will vary based on your selection)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/ACKitComponentsFront_zps0997d996.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00800_zps1211669e.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00813_zps030d1e6e.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00815_zps839b709f.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00812_zps28640ebb.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00806_zps958bb1d4.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00805_zps866c5e1d.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00804_zps8eb12e3f.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/DSC00799_zps1263b095.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/D4315D3A-ED2D-439F-852D-CE8E0816549B-19475-00001F9D375A5534.jpg)
Includes:
-MAF Delete pipe
Huron Speed
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
That would be a completely custom kit, and definitely would not be anywhere near this pricing as it would be fully one-off and custom fabricated. It would also require you cut out some of the metal under the battery to fit piping to the turbo, and the downpipe would be very tight to your AC lines. Can be done, yes, but would be a custom kit and at the moment MUCH more expensive than this kit
__________________
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
One Gone, only THREE left now at this price!!!!
__________________
Thanks Jim!
Only 2 left now, don't miss out!!!
__________________
__________________
Received! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
As the man mentioned.... one left!!!!
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
__________________
Well, those went fast! I will order in some more components to make 2 more of these complete packages available.
Therefore, all initial kits gone, we are adding 2 more now!!!
2 available!!!
2 available!!!
__________________
2 more systems available!!!!
Order direct here: http://shop.huronspeedproducts.com/F...-acblowout.htm
__________________
