ly6 s10 thinking about twin turbos
what up people doing a ly6 swap into a s10 I was gona go nitrous but decided on turbos instead so far this is what I have
2008 chevy 2500 ly6 6.0 with l92 heads(ls3 intake valves) with around 45,000 miles
Vic jr with elbow (2inch carburetor spacer) an 90mm TB
Edelbrock billet fuel rails with 80lb injectors
340lph Aeromotive in tank pump
25% under drive pully set
Texas speed 228/228 588/588 114lsa cam with dual valve springs an tsp push rods
Vvt delete kit
Tsp ported ls6 oil pump
160f thermostat
Double roller timing chain
4l80e stage 2 tranns
3000 tight stall
3.73 gears with posi unit
I was looking at getting 2 of these ON 3 performance 76mm turbo here are the specs
dum
Cold Side:
dumCompressor Wheel 76mm
.80 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer-dumdumdum76.71mm
Exducer-dumdumdum102.36mm
dum
Exhaust Side:
dumExhaust Housing T-4 Flange
.96 ar Exhaust Housingdum
3.0" Vband outlet
Inducer-dumdumdum74.5mm
Exducer-dumdum65mm
what yaw think??
Vvt delete kit
160f thermostat
3000 tight stall
dum
Cold Side:
.80 a/r
dum
Exhaust Side:
3.0" Vband outlet
Exducer-dumdum65mm
what yaw think??
An im buy a header kit an build them my self
An for power If I get close to 800hp ill be happy lol
Yea I was lookin at those did you tig or mig weld them?? Yea ive seen a 4.8 70 camaro running those turbos an I think at 10psi he was running 9s at 1/4 I thinkin of 0n3 70s or maybe even the on3 76s because ill be stroking my 6.0 (364) to a 402 by next december
Yea I might just do the 70s ima be running a 340lph fuel pump with 80lb injectors would that be enough fuel flow
