1500HP E85 Fuel System Daily Driver
I had the red aeromotive belt driven pump ordered and the tall ***** shaped aeromotive reg. Might just order the same stuff again...
http://fuelinjectorconnection.com/sh...p?productid=43
or
http://fuelinjectorclinic.com/ls1-ls6/IS301-2150H
BTW-pm me a email address I can send you what you requested.
My real goal is around 1200rwhp. I just want to overdo the fuel system.
http://mightym0use.wix.com/mm-solutions
I ordered belt driven.
AEO 13113 - reg
AEO 17241 - pump kit with big block mandrel. Red pump. Same bolt pattern as LS ATI balancer.
RPM500 - filter from fstperformance with 2 spare spin on filters
2200cc injectors from Fuel Injector Connection.
Turbonetics is NOT going to do much better than any better than my cheap ebays but good luck. Just trying to give you some advice from someone who is actually driving his car on a daily basis. FWIW-My tuner has gone 4.92 on E85 running Twin A-1000's. But hey what does he know.
These turbonetics cost me a fair bit under $1000 a turbo too. TCI hooked me up with turbonetics. I only went them because price.
I'm also scared of the multi pump setups. I just think it's safer to run the gilmer belt driven mechanical pump.
You're using the Holley EFI yeh? How do you find that?
A belt drive is definitely the way to go especially if you have the money. I love the Holley. It works great for dummies. lol
Can't afford the Holley
. Using stock truck ecu with hp tuners and flex fuel sensor.
