1500HP E85 Fuel System Daily Driver
Old Nov 8, 2013 | 12:21 AM
  #41
p8ntslinger676's Avatar
Originally Posted by Anchor
Cool. So the belt driven pump can pull through the walbro?
No, I was more or less planning on teeing it in post mechanical pump so it won't back feed through the system. The mechanical is going to need to be fed from a bottom sump on the tank. Mechanicals don't pull very well so you have to gravity feed them to help prevent cavitation, that's why it's recommend mounting them as low as possible. I'm going to be running two feed lines to the front. One -10 to feed the mechanical and one -6 priming line and have a single -10 return from the big space shuttle regulator back to the tank.
Old Nov 8, 2013 | 12:28 AM
  #42
Anchor's Avatar
That's not a bad idea. The way i've been told it can be done is Y'd in pre mech pump.
Old Nov 8, 2013 | 01:17 AM
  #43
97WS6SCharged's Avatar
Any reason you didn't look into some of the staged injection setups?
Old Nov 8, 2013 | 03:46 AM
  #44
Anchor's Avatar
Never really thought of it hey. You mean like a 16 injector setup?
