brake boost vs t brake
Old Nov 7, 2013 | 01:30 PM
ls05mustang's Avatar
Default brake boost vs t brake
is it easier to brake boost or a t brake to stage with?
Old Nov 7, 2013 | 01:53 PM
WheelsUp84z's Avatar
brake boost into first beam, bump to second, hit trans brake, let'er rip. Its easiet to do when you have a 2-step on the footbrake and trans brake (3 step i guess technically). Or if you have one of them sweet T-brake bump boxes that Leash makes.
Old Nov 7, 2013 | 01:56 PM
edwardzracing's Avatar
Sorry for the "newbie" question, but can you explain what you mean by "bump to second" ?
Old Nov 7, 2013 | 03:32 PM
slow67's Avatar
Gingervitis Addict
Bump into the 2nd staging beam.
Old Nov 7, 2013 | 03:52 PM
93camaro_zzz's Avatar
Said it perfectly. And by bump to second, he is just meaning to moderate the foot brake to let the car bump forward into the second light. If you JUST light the 2nd beam (Shallow staging) then when you get on the transbrake, the car will naturally roll forward about an inch or two, and you will be staged in the middle usually. Then like Wheelsup said.... let er' eat!
Old Nov 7, 2013 | 08:09 PM
Mrmooney's Avatar
Won't t brake usually make stall go higher then stall rated ie my 3500 stall goes to 4500 making full boost on brake. I have a 2 step by just wanted to see how high it will go.
Old Nov 8, 2013 | 07:49 AM
skinnies's Avatar
leash pulse box makes it cake
