Low mph? 9.8 @ 138mph
Old Nov 8, 2013 | 11:22 AM
SPRAYED 01's Avatar
Here are the graphs from 10 month prior same setup up minus I didnt have the boost activated cutout on yet, it was the same dp but dumped. I verified the cutout fully opens every time though but watching it.
So in these graphs the springs are 3 years old, has harland sharp roller rockers, plug gap at .028 and 5/16 pushrods. If anything these should have a massive dip. But they look good.
Attached Thumbnails Low mph? 9.8 @ 138mph-speed-dyno1.jpg   Low mph? 9.8 @ 138mph-speed-dyno2.jpg   Low mph? 9.8 @ 138mph-speed-dyno3.jpg
Old Nov 8, 2013 | 11:23 AM
SPRAYED 01's Avatar
I also find it odd that I some how gains over 100 ftlbs from one dyno to the next. Both are with converter locked.
Old Nov 8, 2013 | 11:37 AM
ajrothm's Avatar
Originally Posted by stock48
A head wind like that will easily knock off 2-3 mph.
+1
There is the missing 2 mph right there.. ^^^
Although for 800rwhp+, at 3800 lbs I would expect a little bit more MPH.. But it's not far off..
I'd figure out your rev issue first, then I bet the mph will follow.
Old Nov 8, 2013 | 01:08 PM
HydroStream6's Avatar
ET and MPH match that stellar 60' in my book. I wouldn't worry about it too much.
I MPH a lot faster at the same ET, but my car only pulls 1.6s and I'm probably making a touch more power. I wouldn't put much weight in the dyno numbers.
Old Nov 8, 2013 | 02:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What's your current raceweight Alex, something like 37xx right?
Old Nov 8, 2013 | 02:28 PM
LS1Tech Co-Founder
And gear?
I think are you in the zone.
Old Nov 8, 2013 | 02:38 PM
SPRAYED 01's Avatar
Its like 3810 now,325 gear
Old Nov 10, 2013 | 04:04 PM
SPRAYED 01's Avatar
What bothers be is the dyno graph difference. In the speed inc dyno it pulls clear to 6300, then different dyno same exact setup same timing map it loses 800 rpm of power.
What else can wear out other then springs, push rods, spark plugs that could cause that? Weal coils?, they are heat sink truck coils.
