debating ditching on3 70's on max effort 4.8.. thoughts?
Old Nov 9, 2013 | 02:32 PM
slowlsx's Avatar
Default debating ditching on3 70's on max effort 4.8.. thoughts?
The more I think about it, the mire I want to run more efficient turbos, I have a grasp on single turbo stuff, but im a little lost on turbines and AR's on twin applications and especially small cubes. I have a few turbos in mind and all should make 1200whp for future plans which will be a forged 290-347ci.
Quick run down
4.8 shortblock from 2010 truck
Stock 853's milled .030 (9.5:1?)
Kmj studs
ARP Rod bolts
Holley Hi Ram
218/218 112*
Th400 with brake
PTC Converter
3200lb race weight
And obviously twinn turbos.
Currently have a set of On3 70's which have a 65mm turbine amd .68AR
The turbos I have in mind
Turbonetics Tc66 which have a 68mm turbine and .81AR housing
Turbonetics 6665 "Lety" 66mm comoressor, 65mm turbine and .81AR housing
Precision 63/68 which can be had in .68 or .81AR
Borgwarner s362 with 68mm turbine and .81AR
Billet S462 ETR-HO with 68mm turbine and .88AR
What do you guys think? I wajt something that will come up quicm which shouldn't be that difficult on a 2 step and brake.
Old Nov 9, 2013 | 06:30 PM
stevieturbo's Avatar
BW 362FMW ?
No matter which unit, the lighter billet wheels dont cost a huge amount more, so would be worth going for.
I'm sure Forced Inductions or Work turbochargers, or any similar guys can build you units to any spec you want, with any choice of turbines and housings.
Although at least with the Garrett, T'netics, Precision ranges you will have a much wider selection of turbine housings to play with compared to the BW's
Old Nov 9, 2013 | 07:52 PM
slowlsx's Avatar
BW 362FMW ?
The s462 in the list was on FI's website, im guessing its a s400 housing with billet 62mm wheel, that one got my interest the most. Ill check out the 362fmw
Old Nov 9, 2013 | 08:14 PM
cory32690's Avatar
If u already have the on3's try them...don't get me wrong something like bw s362 or 366 may be a better all around quality turbo and you will more than likely make more horsepower per psi but for the price of the on3's and a potential to make 1200 rwhp with a set I would say screw it and use them
Old Nov 9, 2013 | 08:46 PM
wicked z28's Avatar
Wicked 69 is having great success with them not sure how much hp though but fast just try them.Im doing on3 70s on a 408 but just hoping for 900 hp plus.
Old Nov 9, 2013 | 09:14 PM
stock48's Avatar
9 Second Truck Club
Almost be cheaper and easer to keep those and ditch the 4.8 for a 6.0. That's going to be hard to get moving with a 3200 converter.
Old Nov 9, 2013 | 09:22 PM
slowlsx's Avatar
Raceweight is 3200 lol. The converter is a 3600-3800
Old Nov 9, 2013 | 09:36 PM
Wicked69's Avatar
Instead of changing turbos I'm with stock48. Sell the 4 8 and get a 6.0. I'm running 5.99 @3720lbs so with 3200 u would be flying!!!!
Old Nov 9, 2013 | 10:42 PM
stock48's Avatar
9 Second Truck Club
Yea read it wrong on my little pos phone lol
I still think the 6.0 would be alot better deal.
Old Nov 9, 2013 | 11:33 PM
T76s10's Avatar
With the 6.0 would the 70's do 1200 to the wheels? A guy maxed the 76 at 600whp on a 6.0. With the 4.8 I think it would be dooable but I think you'll need 76's for your goal with the 6.0.
Old Nov 10, 2013 | 12:17 AM
stock48's Avatar
9 Second Truck Club
They might but you don't need 1200 RWHP to run low 5's at 3200 lbs. Just depends if you're after RWHP numbers or track numbers I guess. The 4.8 will likely make more pk hp at 30+ psi of boost but avg power under the curve will be way down vs the 6.0 IMO. I think the 4.8 will need to leave around 4800 to 5K rpm and spin 7500 to get it done. A set of billet 62's would work really well on the 4.8 but they are not cheap. Those 70's on a 6.0L with the 218 cam he has would work with that converter, and have power to burn.
Old Nov 10, 2013 | 12:23 AM
slowlsx's Avatar
I agree on your first sentence!
If I were to keep the 4.8 , which billet 62's do you think?
Old Nov 10, 2013 | 01:00 AM
stock48's Avatar
9 Second Truck Club
Precision billet 62/62's seem to make good power if you can get a set that will last. I've seen quite a few of them blow up. A good pair of billet 62's prob would make similar power to a billet S480. Jose might be able to do a custom set of billet Tnetics but won't be cheap. I would keep turbine around 62 and a tight Ar. They can build you a converter that will spool the 70's but it's going to be high strung and sloppy driving around. You might light the 62's with a 3600 but It will prob still be soft in the 60' with less than 4500 rpm launch.
Old Nov 10, 2013 | 02:19 AM
a98ws6's Avatar
Id go with a 370,tfs 255's, and a bw s475
Old Nov 10, 2013 | 07:42 PM
T76s10's Avatar
I thought the op was after 1200whp like stated in the original post. Keep the 70's and get a 6.0. Spool will be great
Old Nov 10, 2013 | 07:58 PM
slowlsx's Avatar
No no, I wanted turbos to support that fir future plans. The 4.8 is getting used, I wajt to see what kind of power it will support..
Old Nov 10, 2013 | 08:00 PM
T76s10's Avatar
Ok got ya
Old Nov 11, 2013 | 03:49 AM
Having used both the 6262 and 6266CEA on smaller engines...there really doesnt seem to be any negative at all opting for the larger turbine.
Spool was basically the same on the engine, but the 6266CEA made a lot more power. Although that was against the old 6262 cast wheel unit
