Holley mid rise install
Old Nov 9, 2013 | 09:49 PM
1bad03snake's Avatar
Default Holley mid rise install
I put a Holley mid-rise on My LS swapped mustang. Here is the bracket I made
Old Nov 9, 2013 | 09:50 PM
Holley doesn't offer much help with this. It's a c4 b&m bracket and a stock f body bracket I chopped up and welded. Hopefully this helps someone else down the road
Old Nov 9, 2013 | 10:09 PM
4DRUSH's Avatar
Looks good, thanks for sharing
Old Nov 10, 2013 | 02:29 AM
a98ws6's Avatar
You should sell those brackets.
Old Nov 10, 2013 | 02:51 AM
I might make another if I have time this week.
Old Nov 10, 2013 | 07:27 AM
Sarg's Avatar
Yeah, I had to make a bracket for my regular hi ram as well. Silly they don't sell one!
Old Nov 10, 2013 | 09:25 AM
JAX04's Avatar
Well if its one thing you can count on with HOlley, its for them to drop the ball....
As far as the bracket, nice work, looks good and original.
Old Nov 11, 2013 | 07:37 AM
Holley definitely dropped the ball
Old Nov 11, 2013 | 08:25 AM
ss performance's Avatar
I would like to hear more on your build.
What size engine, what RPM do you expect to pull, what sort of HP is your goal?
I have looked at the mid rise but am not sure if it would fit my needs.
Thanks
Old Nov 11, 2013 | 10:33 AM
Trl_ws6's Avatar
Thanks
Yeah would love to know the same. Was this a build already down where you could do a dyno/power comparison and so forth.
Thanks
Old Nov 11, 2013 | 02:45 PM
345LSX's Avatar
has anybody tried this intake in a 4th gen f-body ??
Old Nov 11, 2013 | 04:04 PM
ShredSled's Avatar
Looks legit. Maybe you really should bang out a few more and sell them.
Why and how would Holley not make nor include one with the intake!? They just bargaining that most buyers these days are DBWire???
Even more confusing, who came up with the placement/ bolt spacing? Why no do like FAST and at least enable use of the OE fbody bracket?
Old Nov 11, 2013 | 05:53 PM
It gets better, the intake is set up to run a LS3 map... Why design an intake for a ls1/2 with LS3 parts??
my setup is a 6.0/ LY6 bottom end with ARP bolts 317 heads tu1 cam and a turbonetics TC78. I plan on swapping cams and rebuilding my hotside with stainless this winter. I shift at 6200 RPM.
Old Nov 11, 2013 | 07:11 PM
roninsonic's Avatar
I'd like to see one of these on an f body as well...
Old Nov 11, 2013 | 07:12 PM
4DRUSH's Avatar
Ha Ha, good point
I welded a -4 bung over that hole
Old Nov 11, 2013 | 07:15 PM
One of the problems I see with the mid rise in a NA is it only pulls to 6500 rpm. I'm guessing that's in a 5.7 so if you have a 6.0 or 6.2 you lose some rpm. if you are building a stroker you lose even more.
