Tall deck LSX block for 408 build.
Old Nov 10, 2013 | 05:37 PM
RonA's Avatar
Default Tall deck LSX block for 408 build.
Are any of the shops offering the correct rod/piston combo's for running a 4" stroke with the tall deck LSX block? Seems like it would have advantages over the stock deck height on a boosted motor.
Thanks.
Old Nov 11, 2013 | 05:05 PM
Firehawk441's Avatar
A 4" stroke in a 9.75"- 9.8" deckheight will give you a heavy, undesirable piston.
A 4.25" stroke with a 6.4" rod and that deckheight will make for a better build.
Old Nov 11, 2013 | 05:44 PM
B18B1LS1's Avatar
Ron on a gasser site! There goes the neighborhood, welcome buddy!
Old Nov 11, 2013 | 05:54 PM
dezlfrek's Avatar
right..
Ron just go bigger like 454 at that point.
Old Nov 11, 2013 | 09:02 PM
RonA's Avatar
Thanks. So far, the hardest part is having to say "boosted ". I'm used to everything being boosted. All the different block, bore, and stroke combinations are going to take a while to figure out as well.
Old Nov 11, 2013 | 11:32 PM
Blown06's Avatar
8 Second Truck Club
Have you considered intake options with the tall deck?
Old Nov 14, 2013 | 10:51 PM
helicoil's Avatar
I am using a 3.625" stroke with a 9.750" deck and 6.600" rod.
Old Mar 15, 2014 | 06:02 PM
RonA's Avatar
Seems like a good idea to have the piston stay inside the block at the bottom of the stroke. Not sure why a 6.4 rod with the 4" crank wouldn't be fine with the tall deck.
