Help identifying S/C
Old Nov 13, 2013 | 07:55 PM
daweazel5150's Avatar
Default Help identifying S/C
I came across this S/C on craigslist and was hoping someone could help identify it. Plan on putting it on my '02 5.3l silverado. I know I'll need a Throttle body adapter or new throttle body all together, but what else do I need to look for? How much would a rebuild cost?
Old Nov 13, 2013 | 08:19 PM
MUSTANGBRKR02's Avatar
I would imagine by the looks of it by the time you source all the parts and get it ready for install that you would be right around the cost of a new one.
Old Nov 13, 2013 | 10:08 PM
Pocket's Avatar
Its a magnacharger M112 or M122 unit. Likely the latter with the 4 bolt 90mm J-tube. As long as its got fuel rails and the intercooler brick inside still, grab it, those are all the really hard to find parts. All that Ive seen were for trucks, so the pulley spacing will match your 5.3
Its missing the accessory bracket (easy fab), front heat exchanger(ebay), IC pump, tank, lines, relay and handheld tuner
Rebuilding the headunit is a piece of cake. Grab the $30 bushing off ebay and a bottle of Ford SC oil. Probably wont even need one unless its got tons of miles on it. Grab the pulley and turn it forward and back quickly feeling for slop. That means the bushing is shot. Bearings almost always outlast the car, so dont worry about them
If you dont buy the blower, PM me a link to the ad, I may buy it
Old Nov 14, 2013 | 10:45 AM
Does anyone have a link to a rebuild guide or something along those lines? I'd like to know exactly what to look for when I go inspect the unit.
