Any 8 sec 6spd turbo ls f body's?
Old 11-17-2013, 08:39 AM
  #41
2000RATA's Avatar
Originally Posted by SBE48
We'll who's your buddy? He better be rich lmao
He doesn't have to be rich just not broke.
Old 11-17-2013, 08:54 AM
  #42
turbocamaro125's Avatar
We'll ik a couple ppl that aren't broke and they couldn't get in the 8's....I think it takes more money then ppl think.
Old 11-17-2013, 09:03 AM
  #43
Somebody has to drive a faceplates t56 on the street and street race it????....has to be streetable right?
Yea what's that mean? I know it's not street able like synchro trans.
Old 11-17-2013, 12:21 PM
  #44
p8ntslinger676's Avatar
We currently hold the record with a 6 speed supra. and yes, if you're pockets are deep enough and you know how to drive, 7 second passes are possible while rowing through the gears. car was a 3.4 stroker with a pro mod 91 on it and a custom irs 9" rear end
Old 11-17-2013, 04:01 PM
  #45
DEFYANT's Avatar
I think an F-Body could do it, it will just take some time, and deep pockets.
Old 11-17-2013, 04:36 PM
  #46
SKULL's Avatar
the stock bottom end zr1 just went 8.9's still tr6060
Old 11-17-2013, 05:01 PM
  #47
VIPERSLYR's Avatar
This is just my opinion I agree it does take a good amount of money to purchase the right components to make the hp and suspension to run that # but you don't have to be rich. I'm no where near rich but I have poked away at my car over the past few years now focusing on more suspension pieces to get me to my goals. It takes someone who knows there car and concentrates on set up and tune it's all in the suspension set up witch all of you know. I think there arnt many record setting stick f body's because people make the big jam and love the consistency of a auto and don't wana mess around with trying to figure out a stick car nor can throw gears fast enough
Old 11-17-2013, 05:17 PM
  #48
rotary1307cc's Avatar
or they like something reliable that doesnt shift like a dump truck
someone should stick a v160 behind a lsx
Old 11-17-2013, 09:04 PM
  #49
mrstepheneades's Avatar
Well we all know these boys have deep pockets..
Old 12-25-2013, 09:03 AM
  #50
bcbosley's Avatar
I'm curious what you fast 6 speed turbo guys are running as far as rear end gear ratio? I'm bulding a 408 with s480 right now and planning on running a tick level 4 magnum trans. It seems like everybody goes th400 and I even thought about it myself but I decided to stick with the extra pedal. So without too many fast 6 speed turbo guys out there, I'm having trouble deciding on what gear ratio to run.
Old 12-25-2013, 11:43 AM
  #51
Ryans99ls1's Avatar
Tire size, 1/4mi mph, and rpm determine you gears. You can pretty much assume 28" tire (or larger) so really it depends on your how much rpm you are willing to turn in 4th gear to accommodate your mph
Old 12-25-2013, 12:39 PM
  #52
Moderator
LIL SS's Avatar
What did Harlan run back in 2002 or so with the twin 66 set up? Wasnt it a 6speed before going auto? I want to say it either went vrry high 8's or 9.0..
Old 12-25-2013, 07:54 PM
  #53
Vetal's Avatar
Now I don't understand either how is it that Supras of comparable weight, on IRS, can run a whole second faster????
Old 12-26-2013, 08:20 AM
  #54
AmishAssassin's Avatar
I believe the 6 speed getrags they run (stock late MK4 supra trans) have a stronger design then the t56 and TR6060s. In my opinion.
Old 12-26-2013, 10:50 AM
  #55
93camaro_zzz's Avatar
Originally Posted by mrstepheneades
I plan to stay 6 speed forever.
I remember when I said this. lol But utterly inconsistent sixty foots and two clutch rebuilds later, needless to say, I made the swap to TH400.
Old 12-26-2013, 10:51 AM
  #56
Seems someone should swap a supra trans in an fbody to test this. Lol
Old 12-27-2013, 06:26 AM
  #57
Camaro9969's Avatar
Haha I wanted to do the same and its just not worth it these cars can't do **** at the track when they are turboed unless there's an auto behind them. And the cost to hold all that power together in the drivetrain would be 8000+
Old 12-27-2013, 07:05 AM
  #58
Look at all yge money we waste on these cars lol. What's 8000 in the big picture. I I know if I keep my car for another 10 years I will sink at least another 20,000 into itif not more that's just the way I am.
Old 12-27-2013, 08:47 AM
  #59
UNDER PRESSURE MOD
The Alchemist's Avatar
What are people's thoughts on 6 speed sequential gear boxes? Does that count as a 6-speed?
I personally love seeing guys row fast cars to a fast time. Sure, it's less consistent than having a slush box do the shifting, but it's more exciting to see someone row the gears to me. It's more of a challenge, and as such, the reward is greater.
Old 12-27-2013, 08:58 AM
  #60
ddnspider's Avatar
Received 1,746 Likes on 1,304 Posts
I love these threads that pop up every now and then, making it seem almost trivial. You guys should hang out in the 6 speed section more. There is plenty of discussion regarding going fast with a T56 speed....The issue is weight and power. People haven't kept the 6 speed alive while simultaneously making the car light enough and making enough power. Either the car doesn't make the power to go 8's or it does make the power but it weighs too much and destroys the T56. The torque that the boosted LS motors make over the curve, combined with the weight, always kills the trans; even with trans mods like the oil sprayers on the 3/4 gear. I think it can be done, but it will take a sub 3000lb fbody and ALOT of money in the clutch/trans. It'll have a better shot with a slow 60' and a ton of top end.
Good luck to 99bluefbody trying to go 8's while keeping to class weight rules.
Alchemist...In my opinion, no way a 6 speed sequential counts. Faceplated T56 is about the limit, which I believe is what Joe Honeycutt had.
Quick Reply: Any 8 sec 6spd turbo ls f body's?
