Aster bracket users step inside
Old Feb 5, 2014 | 05:24 PM
  #101
95-1LE-Z28's Avatar
Originally Posted by Chris@CBR
Good afternoon guys.
Pulleys are in stock and ready to ship.
I should be placing an order in the next couple of days...
Old Feb 9, 2014 | 09:57 AM
  #102
stmz28's Avatar
Has any one put one on yet to get a belt size and to see how much more boost it made with just changing to the 8.65 pulley
Old Feb 10, 2014 | 01:57 PM
  #103
white01ss's Avatar
+1
I'm going with a 3.85" blower pulley on my D1SC. This maxes out the blower (62k RPM) at 6730 RPM. This give a little room when shifting at 6500.
Going the next size down 3.7" maxes out at 6468 RPM.
If anyone has belt lengths start throwing them up!
Old Feb 23, 2014 | 09:08 PM
  #104
95-1LE-Z28's Avatar
Order placed. In for some pulley combos and belt lengths.
Old Feb 23, 2014 | 10:08 PM
  #105
Chris@CBR's Avatar
Thanks for the order!
Old Feb 26, 2014 | 03:29 PM
  #106
95-1LE-Z28's Avatar
Thanks for the fortune cookie lol I would have been super confused if i hadn't seen your explanation in another post.
Old Feb 26, 2014 | 04:10 PM
  #107
Chris@CBR's Avatar
I like Chinese......food!
Old Feb 27, 2014 | 08:35 PM
  #108
Tirefire's Avatar
Order placed. Will this ship out soon or do you have to make more pullies?
Old Feb 28, 2014 | 06:02 AM
  #109
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Hi Andy, The last I heard he had them in stock. I'm not sure if you tried to call me back last night or not, give me a call today when you get a chance. Things should be slower for me today. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 28, 2014 | 06:43 AM
  #110
Tirefire's Avatar
Ok Bob thanks..
Old Feb 28, 2014 | 08:05 AM
  #111
Chris@CBR's Avatar
Thanks for the order Andy!
Pulleys are in stock, your order will ship today.
I'll PM you with your UPS tracking #
Old Apr 6, 2014 | 07:47 PM
  #112
conor.davis's Avatar
Anyone have this with the 4.13 pulley and care to share their belt size??
Old Apr 13, 2014 | 12:02 AM
  #113
BTLBABY's Avatar
I'll throw this in here...
The SDCE pulley has about a .250 offset over the factory ProCharger pulleys. I bought a LS2 pump to throw on my car so I could run the 7.65 pulley with my SDCE setup. Well unfortunately it sets towards the crank quite a bit more then the original SDCE pulley. So back on with the 7.250. Boo...
Old Apr 13, 2014 | 07:02 AM
  #114
Firehawk441's Avatar
That would mean that SDCE uses 1/4" longer pedestals then Procharger and Aster.
Thanks for sharing this information.
Old Apr 13, 2014 | 10:00 AM
  #115
NitrOmm's Avatar
On an F1A shooting for 16lbs.... will the use of this oversized crank pulley eliminated the need for the Astor bracket ( as it pertains to belt slip) ?
When I did this type of mod on my Maggie setup I was able to increase the head unit pulley ( create more wrap) and eliminate belt slip. Anyone experiment yet.
According to my calculations for approximately 16 lbs @ 6200 rpm it will require a 4.63" head unit pulley (spinning the F1A @ 62,500).
Will I need an Astor bracket as well ?
Old Apr 13, 2014 | 10:13 AM
  #116
BTLBABY's Avatar
You are correct sir.
Also, the countersink on the back side of the SDCE pulley is about half the depth of the ProCharger pulley. I'm going to line the SDCE bracket up for the factory pulley offset, and I'll report back when I do so you guys will know what the actual offset of SDCE pulley is. Unless Chris gets one in his hands first to get a Micrometer on it.
Old Apr 13, 2014 | 11:11 AM
  #117
stmz28's Avatar
My 370 afr205 heads custom cam victor jr intake f1a with a 8.65 crank and 4.50 blower pulley made 16psi
Old Apr 13, 2014 | 02:17 PM
  #118
NitrOmm's Avatar
Thanks. Aster bracket needed to keep belt from slipping ?
Old Apr 13, 2014 | 09:01 PM
  #119
stmz28's Avatar
I have the aster bracket
Old Apr 13, 2014 | 09:12 PM
  #120
ramairetransam's Avatar
thanks for getting the water pump and doing the work , i was thinking about upgrading to a 7.625 crank pulley and im so glad i saw this . Guess i have to go down below the 3.4 that's on mine now .
