Aster bracket users step inside
Old Nov 18, 2013 | 04:30 PM
Firehawk441's Avatar
Default Aster bracket users step inside
I've read where some of you have had issues where the belt tensioner cuts into the power steering pulley.
Well I had CBR Performance Products...( Company who makes the turbo kits/parts for Modular Turbo) Make up this power steering relocation bracket to use with the Aster bracket so there will never be any interference issues with the P/S pulley and as an added bonus getting a wrench/socket on the belt tensioner is a bit easier.
If there is any interest with others who may want to use this bracket he'll make more of them. The current bracket that's been in production for the turbo guys puts the pump in a different location then this one.
Although I have a Wazee pulley on the pump it is not necessary as the OEM pulley will work fine.
Old Nov 18, 2013 | 05:01 PM
stmz28's Avatar
I was thinking about the Wazee pulley did the belt tensioner still hit? How much will that bracket be?
Thanks
Old Nov 18, 2013 | 05:14 PM
Thanks
The pulley is close but didn't hit, however the tensioner bolt is still a pain to get a wrench on so this bracket took care of that issue.
Bracket was $125.00 and if you choose to use his hose set they're $149.00
Forgot to mention he is going to make a larger diameter crank pulley then the 7.6" procharger pulley also
Old Nov 18, 2013 | 06:15 PM
stmz28's Avatar
Thanks I have been looking to see if any one made a bigger crank pulley. How much bigger was he thinking about making it?
Old Nov 18, 2013 | 06:38 PM
Probably 8" but he was looking for opinions as to what others may want. He mentioned possibly making a couple sizes.
Old Nov 18, 2013 | 07:35 PM
I8UR4RD's Avatar
you running a d1 now? thought you were running the F1-C a while back.
Old Nov 18, 2013 | 07:41 PM
The D1 is only on the engine for these mockup pics.
I currently have an F1A on the car.
Old Nov 18, 2013 | 08:09 PM
35thsscamaro02's Avatar
Keep us informed on a bigger. 8rib crank pulley
Old Nov 18, 2013 | 08:10 PM
WS6 SRT-8's Avatar
Any idea when this crank pulley will be available?
Old Nov 18, 2013 | 08:22 PM
stmz28's Avatar
I would take a 8inch pulley if it fits. I thought I heard before you make more torque with a bigger crank pulley?
Old Nov 18, 2013 | 08:45 PM
Chris is optimistic that he can have the crank pulley ready for mid to end of January.
Old Nov 18, 2013 | 09:37 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I just ran into this issue tonight, as I installed the Wazee pulley over the weekend, and picked up my blower belt today. Problem was easily solved by grinding 1-2mm of the head of the bolt that holds the pulley on the tensioner. I also use a cross beam gearwrench and have no issue fitting it in between the tensioner and the power steering pulley.
Before anyone worries about the strength of the bolt after grinding off a little, originally it's a good 10-12mm tall, so taking off a couple mm is no big deal.
Old Nov 19, 2013 | 05:42 AM
firehawk 385's Avatar
Very Nice.
Props to CBR for thinking of the procharged guys.
Old Nov 19, 2013 | 08:44 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Very nice combination! I would suggest making a one inch larger crank pulley. With the larger crank pulley the Aster bracket might end up working well with an F-1R. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 19, 2013 | 04:24 PM
No Juice's Avatar
Yep, 1" larger is a must. I have an 8.6" here
http://www.midwestlsx.com/forum/show...hlight=max+out
Old Nov 20, 2013 | 06:27 AM
An 8.6" pulley is a very good idea.
Old Nov 24, 2013 | 04:19 PM
I received a couple CAD model pics of the new crank pulley today.
Old Nov 24, 2013 | 06:55 PM
stmz28's Avatar
looks good hope he makes enough of them
Old Nov 24, 2013 | 07:43 PM
This is what I want!!!!!!!!!!! I'm ready to buy this I want a 8.6 pulley!!! :-)
Old Nov 25, 2013 | 07:40 AM
UNDER PRESSURE MOD
Very interesting to see a bigger crank pulley. Should help get more blower rpm, and not worry about belt slip.
